I will Check it tomorrow, now im Not at Home
He’s running Kodi v19 nightlies: ii vero3-mediacenter-osmc 18.8-23 armhf Media Center package for OSMC
which is why the remote improvements don’t work yet. @gmc needs to add the patch
That’s a seriously old version which is over a year old. Latest is 18.8-121.
Yep – he’s missed out on a lot of changes since then.
What i have to do?
If you don’t want nightly builds I’d recommend reinstalling OSMC
Ok, reinstall an installieren the Backup from November from my nas
There will be database changes however, so I don’t recommend trying to restore your library
Or i stay on nighly so long i Can use the stop Button
You can update the nightly yes.
You will need to wait for @gmc to include the updated keymap.
Ok i wait and Then i clean the source
No light at the stop Button
Try a new battery. I don’t think this is a software issue.
All other Buttons works Fine!
Do you see a blue light with those buttons?
If so, there may be some debris obstructing the button.
I dont see a Blue light at any Button
Regarding the blue light, see a picture, here: Pairing the Original Black OSMC RF Remote Control with a Pi/Vero2/4k/4k+
I See the blue light at the Remote, i looked at the Vero
So the blue light turns on and off when you press the stop button?
Yes at the Remote
