Stop Button without funktion
Then I would suggest you reinstall from scratch. I can find no explanation for this behavior and you have a very odd jumble of updates having moved from several different testing branches. I have tested that remote command in all three German keyboard layouts in stable, staging, and Kodi 19 nightly with a fresh install on a Vero just yesterday. This is despite the fact that we are not actually manipulating that particular key and I could find no issue with its function when I tested every single keyboard language OSMC ships with. If there is an issue with the long-press update I am quite keen to find it so it can be fixed before pushing this to everyone, but I cannot reproduce what your experiencing.
F**k :joy:
I press the back button for a long time, it’s like stop
If you could turn on debug logging and both short-press and long-press the stop button several times, and then upload the Kodi log of that I would be interested in seeing that. Your original log appeared to have the button not come back with a valid identifier so I am curious how a long-press version of it would be acting different.
a long press on the back button is like stop! the stop button has no function at all, neither long nor short
Yes, I understood what you are saying. As far as Kodi is concerned though there is a button being pressed, and that button being held down. Kodi would normally need the former if the latter works. If you want to do it another way turn on debug logging and ssh and type in
tail -f ~/.kodi/temp/kodi.log
and then short and long-press the stop button. You will see Kodi logging how it sees the key and what it is doing with it. This is what i’m interested in. You can ctrl-c to exit tail.
Ok, tomorrow
Linux osmc 3.14.29-156-osmc #1 SMP Tue Oct 15 20:21:25 UTC 2019 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Mar 14 17:42:13 2020 from 192.168.178.33
osmc@osmc:~$ tail -f ~/.kodi/temp/kodi.log
Summary
2020-03-16 14:16:50.754 T:3837502176 DEBUG: Skin Helper Widgets --> Kodi_Monitor: sender xbmc - method: Player.OnAVChange - data: {“item”:{“id”:7,“type”:“movie”},“player”:{“playerid”:1,“speed”:1}}
2020-03-16 14:16:50.784 T:3480228576 INFO: CPythonInvoker(25, /home/osmc/.kodi/addons/script.tv.show.next.aired/default.py): script successfully run
2020-03-16 14:16:50.784 T:3480228576 DEBUG: onExecutionDone(25, /home/osmc/.kodi/addons/script.tv.show.next.aired/default.py)
2020-03-16 14:16:51.110 T:3480228576 INFO: Python interpreter stopped
2020-03-16 14:16:51.110 T:3480228576 DEBUG: Thread LanguageInvoker 3480228576 terminating
2020-03-16 14:16:51.247 T:3845894880 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnAVChange - data: {“item”:{“id”:7,“type”:“movie”},“player”:{“playerid”:1,“speed”:1}}
2020-03-16 14:16:51.250 T:3845894880 DEBUG: Previous line repeats 2 times.
2020-03-16 14:16:51.250 T:3845894880 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnAVStart - data: {“item”:{“id”:7,“type”:“movie”},“player”:{“playerid”:1,“speed”:1}}
2020-03-16 14:16:51.250 T:3845894880 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnAVChange - data: {“item”:{“id”:7,“type”:“movie”},“player”:{“playerid”:1,“speed”:1}}
2020-03-16 14:16:55.276 T:3344261856 DEBUG: CPtsTracker: detected pattern of length 1: 40000.00, frameduration: 40000.000000
2020-03-16 14:17:01.718 T:4045402848 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 400ms repeat: 80ms
2020-03-16 14:17:01.719 T:3480228576 DEBUG: Thread Timer start, auto delete: false
2020-03-16 14:17:01.736 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:01.737 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:01.737 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:01.737 T:4066332672 DEBUG: HandleKey: 0 (0xf200, obc-61697) pressed, action is
2020-03-16 14:17:01.894 T:3480228576 DEBUG: Thread Timer 3480228576 terminating
2020-03-16 14:17:01.897 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:03.614 T:4045402848 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 400ms repeat: 80ms
2020-03-16 14:17:03.615 T:3480228576 DEBUG: Thread Timer start, auto delete: false
2020-03-16 14:17:03.617 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:03.617 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:03.617 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:03.617 T:4066332672 DEBUG: HandleKey: 0 (0xf200, obc-61697) pressed, action is
2020-03-16 14:17:04.017 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.017 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.018 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.018 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.097 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.097 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.097 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.097 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.177 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.177 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.177 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.177 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.257 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.257 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.257 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.257 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.339 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.339 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.340 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.340 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.416 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.417 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.417 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.417 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.498 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.498 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.498 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.498 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.578 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.578 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.578 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.578 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.658 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.658 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.658 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.658 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.737 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.737 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.737 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.737 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.818 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.818 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.819 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.819 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.897 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.897 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.897 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.897 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:04.978 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:04.978 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:04.978 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:04.978 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:05.057 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:05.057 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:05.057 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:05.057 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:05.138 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:05.138 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:05.138 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:05.138 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:05.217 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:05.217 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:05.217 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:05.217 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:05.297 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:05.297 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:05.298 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:05.298 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:05.377 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:05.377 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:05.378 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:05.379 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:05.457 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:05.457 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:05.458 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:05.458 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:05.536 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:05.537 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:05.538 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:05.538 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:05.616 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:05.617 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:05.617 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:05.617 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:05.716 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:05.717 T:4066332672 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2020-03-16 14:17:05.718 T:4066332672 DEBUG: Previous line repeats 1 times.
2020-03-16 14:17:05.718 T:4066332672 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-03-16 14:17:05.750 T:3480228576 DEBUG: Thread Timer 3480228576 terminating
2020-03-16 14:17:05.757 T:4066332672 DEBUG: Keyboard: scancode: 0x80, sym: 0x0000, unicode: 0x0000, modifier: 0x0
2020-03-16 14:17:20.645 T:3890766560 DEBUG: Thread JobWorker 3890766560 terminating (autodelete)
2020-03-16 14:17:20.645 T:3728134880 DEBUG: Thread JobWorker 3728134880 terminating (autodelete)
2020-03-16 14:17:20.646 T:3970499296 DEBUG: Thread JobWorker 3970499296 terminating (autodelete)
2020-03-16 14:17:20.646 T:3711349472 DEBUG: Thread JobWorker 3711349472 terminating (autodelete)
^[a^C
o
(mod edit)
Thanks for that Mirko. If you do a clean install your remote should return back to full working condition.
I still wait for a New Update
A clean install is a lot of work
A new update will likely not fix this. I think that when you switched to the testing builds and then pulled back out of those you missed an update last year that tweaked Keyboard support for your remote. You didn’t notice a change because we were using eventlircd still to present these to Kodi as remotes via lirc. Because you were on staging updates you recently got the updates where we switched that off and moved to keyboard input to provide the ability to use long-press actions. Switching back off of staging does not undo these changes, nor will a future update on your existing install.
Under any normal situation this would not have ever happened. I can understand the headaches involved with starting over from scratch. However there were stated risks that you agreed to when you moved to daily updates and what happens on your system going forward from here, unless you choose to do a clean install, will be completely unpredictable and not something we can be expected to support.
I think you can probably get away with keeping your library and most of your settings by using the backup/restore option in the My OSMC add-on’s backup section. Your log shows your using Kodi 18.2 and so I don’t think there would be a conflict as was earlier suggested.
i have download the installer, choose vero4k+ and selected my usb stick! then i download the image, but evertime failed to write the image…
f++cked up
What operating system are you using?
macOS
now i run this with ssh
wget http://download.osmc.tv/installers/diskimages/OSMC_TGT_vero3_20200204.img.gz -O- | gunzip -c | sudo dd if =/dev/mmcblk0 bs=1M conv=fdatasync
it’s of= not if=
Don’t run that command directly on the device or you will brick it.
Run it on the Mac (and check the /dev/) is correct, probably rdiskX
to late, i think its brick
i have the tut form this forum
What can i do? Nothing?
Why can i Not a reset over the menu! 100€ for nothing
What have you done?
Have you actually written the image directly to the eMMC?
yes, why the mac installer doesnt work
what i have to do?
oh my god, please delelte the thread from the forum
Why should a thread talking about the Pi be removed? It does not tell you to run those commands on a Vero.
It was to late, i run the command direkt
