I thought I already posted this a while ago but can’t find it so probably not.
There is very small stuttering in many video’s. You hardly see it, but I do. Specially when the camera is moving slowly. When the camera doesn’t move it’s not noticeable.
I’m not sure if it’s only in HEVC content. Everytime I see it I think “write down which movie you’re watching” but then later on forget about it.
I tried a while ago to record it happening so I can show you but it was very difficult to record.
Do you know about this issue Sam?
Is it perhaps already on the list somewhere to fix?
Sorry to hijack the post, but i have noticed this as well, it would occasionally occurs prior to the April update but it seems to happen much more regularly.
i have tested the files on other devices and they play perfectly, however via the Vero 4k i get the occasional stutter, its not constant and does seems to happen at points of movement when the camera is panning around.
I have adjust refresh rate on start stop enabled and in order to do a test, i disabled this and played the same file and i didn’t notice the same stutter, albeit i didn’t watch a whole episode so its possible i hadn’t watched enough to suffer a stutter.
General
Unique ID : 188522254614913128514135460421638784144 (0x8DD410C6E091B0AA8C53E64DB0AF8490)
Complete name : /Volumes/3Tb/TV/The Flash (2014)/The.Flash.2014.S03E21.1080p.mkv
Format : Matroska
Format version : Version 2
File size : 2.00 GiB
Duration : 42 min 8 s
Overall bit rate : 6 803 kb/s
Encoded date : UTC 2017-05-10 11:54:47
Writing application : mkvmerge v9.0.1 (‘Obstacles’) 64bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 156 ms
Stream size : 116 MiB (6%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
It isn’t always perceivable as my wife sat through a couple of episode of TV and didn’t notice a thing wrong, but I am a little OCD about these things and once i know it is there, I notice it all the time.
I also have this issue on both my Vero 4Ks (connected to two different LG TVs, 2K & 4K), it’s pretty minor but occuring across all media.
My partner isn’t noticing it, but I can see it immediately - probably as I have a background in video production and am used to spotting issues like this.
No motion-smoothing or other horrible motion-modifying settings are enabled on the TVs. Media is coming off a NAS, but the problem persists if playing directly off a USB drive. “Adjust Refresh Rate” is on “Start/Stop” but the same problem still occurs on “Always”.
This is a different issue to the massive stuttering/skipping I posted about a while ago, which was only occurring on VC1-encoded Blu-ray MKV files (which I solved by simply re-encoding them to 10bit H.265 HEVC).
Edit to Add: Despite the minor “early-days” bugs which seem to be quickly fixed as they come up, the Vero 4K is a great device which is very well supported, and I’m very happy with it. Thanks to Sam, the Vero team, and the OSMC community!
I can see this stuttering as well. Especially in 1080p movies. I thought that it is just HEVC at first, but now more and more 1080p x264 also appear to stutter. All options are default except buffermode set to 2. I didn’t see this issue on RPi3. I have pretty old Sharp TV, I’ve never messed with any TV features before.
It seems like the CPU cannot handle the video for fraction of second and then the stuttering appear - also it is pretty random - when I rewind it is not usually appearing in the same moment. Of course, since it is HW decoded, the CPU load is pretty idle. I’m just trying to describe how it looks like.
I am using ethernet and new HW NAS and I easily get 10MBps on vero (using dd) reading from hard mounted nfs share, so it is definitely not the network issu. I was even considering that I imagine this, but then I came across this topic.
It is ok with “Adjust Refresh Rate”, but there is annoying flapping (renegotiating) hdmi connection every time I start and stop video. So knowing what is causing the stutter, I recognized that majority of movies have 24 Hz refresh rate so I’ve just changed the default kodi refresh rate to 24 and I believe that for like 99% of movies it will be ok. For the rest I can live with the renegotation.
Unfortunately I am witnessing the stutter across pretty much all media regardless of refresh rate or the codec used, it is worse on some but i haven’t been able to narrow down a cause and its pretty much frustrating.
Not going to lie, disappointed i am having to resort to other methods to play back media i bought the vero 4k to do.
Yes to both unfortunately. At first i thought it might be the file, but they play perfectly on other devices so it seems to be specific to the Vero 4k.
I have tried different NAS (i have three) with both wifi and Ethernet as well as local storage and the problem is the same in all scenarios.
The issue for @msieminski was seemingly that Adjust Refresh Rate was not enabled. This can cause video to not be played back smoothly, particularly during something like a panning shot.
A fresh debug log playing back a file from the eMMC would be good.
General
Unique ID : 210630065156078365692831925866606503038 (0x9E75DFFDDA410882BF25BCA490FA247E)
Complete name : /Volumes/UNTITLED/Test.mkv
Format : Matroska
File size : 2.13 GiB
Duration : 42 min 33 s
Overall bit rate : 7 172 kb/s
Encoded date : UTC 2017-05-11 10:33:48
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 384 kb/s
Bit depth : 16 bits
Delay relative to video : 21 ms
Stream size : 117 MiB (5%)
Language : English
Default : Yes
Forced : No
