Vero 4K:
I thought this issue might be unique for me but after searching this forum as well as Kodi’s it seems that many people have the same problem, i.e., having to enable Subtitles for every video.
I’ve tried every suggestion I found but nothing works.Maybe this is one of those little mysteries that defy all solutions
lol.
Anyway, I thought I’d ask the question again, just in case there’s a new answer.
Thank you for reading
Cleo
Set preferred subtitle language in settings - player
I tried that with ‘Original language’ and ‘User interface language’. Actually, I think you might have suggested that in an earlier thread.
But neither worked.
Are you saying to set it at English, then?
Down below, the description of that function seems to imply it only defaults to the chosen setting if there’s more than one language available. Which is rarely the case for me.
When you were playing a video you brought up the OSD, went to settings>subtitle settings then turned on “enable subtitles” and then clicked on “set as default of all media” and then clicked “yes” on the screen that popped up, and that did not stick?
No, I tried that 5 or 6 times and it just kept reverting to ‘OFF’ when the video was restarted.
That was in the KODI settings but I’ve also gone in through the player during a movie, where you get the option to ‘Save as default for all fiIes’.
It must be a tiny programming flaw in KODI that perhaps doesn’t trouble most users who don’t rely on subtitles.
Edit: I put that badly. In essence, I tried changing the settings in two ways - via the KODI ‘media player’ settings, as well as via the the player during a movie play.
I just tested this. While watching a TV episode, I brought up the OSD, went to subtitles and turned them on and selected “Set as default”.
Watched another episode and got subtitles. Rebooted and still got subtitles.
What skin are you using? Debug logs may help us see why you are not getting the subs.
reboot the OSMC device
reproduce the issue
upload the log set either using the
Oooer. That might be a bit too advanced for this blonde brunette, but I’ll try.
The skin is, I think, the default Estuary one
Maybe it’s an issue with the skin. Try the default OSMC skin and see what happens.
Just re=read that previous post. I am getting subtitles ok, it’s just that I have to turn them on every time I start a movie. Which is every time cos I always have a subtitle with my vieos,
So it’s only movies that you see this with? I’ll try that.
OK, I can confirm, looks like a Kodi bug. The setting works fine for TV shows, but not for Movies.
Sorry, no. I use subtitles for every video I watch through the Vero, whether they be movies, docos, TV shows etc.
“OK, I can confirm, looks like a Kodi bug. The setting works fine for TV shows, but not for Movies.”
Well, I’d call ‘Disenchanted’ (Matt Groening) a TV show rather than a movie, and the same thing happens with that. As well as any other TV show
I guess it’s not about of what you would “call” it but if it is in the Library under Movies or TV Shows.
I saw comments on the KODI website about someone with the same problem, and there was a suggestion that his problem was caused by him using the File Explorer and not the Library.
I also use File Explorer, maybe that’s the problem.
That could explain why it’s not working for TV shows, but I do think that there is a bug for Movies from my limited testing tonight.
Try setting up a library and see if that helps.
bmillham, thanks, but, as I explained in my last post, which was about not being able to search for specific movies by name (which turned out to be a function of the Library but not the File Explorer), that I prefer not to use the Library.
So, like doing without a Search function, I’ll put up with turning the subtitles on manually.
Both items are only niggles.
Thanks to all who’ve answered. ![]()
I never use the search feature, but just tried it and it works fine. Found all kinds of hits on the word I searched on, including the movie I had in mind. You may want to try the library again.
You don’t need a library for this and it works just fine regardless of where you start the video from (including file explorer). I think you might have gotten tripped up in your testing method. If you enable or disable subs when your playing a video that gets stored in the database even for files that are not in the library. Thus you can only test whether it works with files that had not had their sub setting touched while playing them. Any files that had been touched will have to be manually switched as I am pretty sure there is no way to force an override of a saved sub state.
Check .kodi/userdata/guisettings.xml and make sure it shows <showsubtitles>true</showsubtitles> under <defaultvideosettings> (or post a log so we can check for you).
The problem people normally have is that the name of their prefered subtitle does not match the exact name of a subtitle. If someone had their UI set to ‘english (US)’ and prefered sub set to ‘user interface language’ then it will not find an english sub as those are always titled ‘english’.
When I was testing, I played a movie, set subs to on and then set default for all. Stopped the movie and started again and no subs. Went to watch a TV Show (that I had already watched) and got subs. There is a bug in Kodi here.
All my subs are embedded.
