Hi, I have a Pi3 and a 23" Touchscreen HANNS-G HT231HPB.
OSMC with Kodi 17 works great. Touchscreen works in the top left corner correctly, but the further I move away the more the cursor deviates. I guess, I need to calibrate the touchscreen. Is there a how to do for Kodi 17?
I am just installed the Kodi 17 Krypton Beta build.
If I go into OSMC Update and to a scan for updates I see “Downloading Updates”, but after a few seconds I get:
OSMC Update Error --> Error installing: Please report this on the OSMC forum.
Where can I get a log to find this problem?
I am new with OSMC. Thansk for help.
Thanks that fixed the problem with Update, but not the problem with the repository addons
I get again “Can’t connect to the repository” if I select “Install from Repository”.
That’s because the repository URLs are wrong. The fix for this is documented in this thread a few posts up. You can find the post using the “search this thread” facility.
Testing both builds 17 and 18 is there a major change in video processing ?
Because 17 runs smooth on my HDhomerun Comcast and 18 on some HD channels 1080 studders
