[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
i think it was 218 that change the bahavior.
I’m also guessing 218:
[Linux] add libinput backend for non window system platforms (PR:13176 3, 14 commits, 30 files changed)
If you read the last comment, https://github.com/xbmc/xbmc/pull/13176, there is issues with vnc on xbian. The ā€œdisable grabbing of input devices in libinput handlerā€-patch later made keyboard work i think, not sure tho.
I went through the pages…total and absolute chaos lol.
17.8-228, 9 May 2018: Based off OSMC commit (968c45b8) and newclock5 (9d919b65c)
inputstream.adaptive:
  • Set privacy_mode only if no certificate is given / fix some missing jni local refs (e9ecb4c)
    *Use jcast for byteArrays / provide cmakelists for obsolete ndk (43e02b8)
Includes latest addons: inputstream.adaptive (43e02b8, +2), inputstream.rtmp (8920456, +1), peripheral.joystick (80224e1), pvr.argustv (377f796), [url=https://github.com/kodi-pvr/pvr.demo]pvr.demo/url, pvr.dvblink (c61ea73), pvr.dvbviewer (098d23c), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (dbdc96e, +3), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (1244e14), vfs.libarchive(1b00b57, +1)
OSMC Skin (v18 Alpha) Updated:
Skin build 17.9.3-3
  • Adjust now playing dialogs (a92689)
  • Adjust TV show list view titles (0ab718d)
Can you use the search in Addons anymore ?
I am getting a sad face and this error msg:
16:45:35.040 T:1800393440   ERROR: GetDirectory - Error getting addons://search/
16:45:35.041 T:1918333536   ERROR: CGUIMediaWindow::GetDirectory(addons://search/) failed
Not getting a sad face, but when I click on search nothing happens. Might be a bug, will look into it.
Look like the problem was introduced in 223
tried to install / deinstall addons
OSMC is chrashing while installing or uninstalling addons
this happended with
netflix
redbulltv
tmdb
looks like a general problem with my installation
please check.
thanks
log:https://paste.osmc.tv/bosixaqoxa
Yeah, not getting a sad face all the time…but 1 out 10 i will when i try it…I was just unlucky and got it on the first time at first
running kodi
tried add-on search, but search window is not opening.
sometimes kodi crashed as well while trying to open search for add-ons
please help
log:
https://paste.osmc.tv/tesazoheme
Both these are known issues. See first post. Hopefully will be fixed soon.
with 17.8-228
I experienced a problem with mouse usage connecting via VNC.
Please check.
Thanks T
Already reported 5d ago, please check the posts in this thread before posting.
17.8-229, 14 May 2018: Based off OSMC commit (fc7f311a) and newclock5 (6cf9120)
XBMC:
  • Resolution: User current resolution - desktop might be something else (PR:13868, 1 commit, 1 file changed)
  • [guiinfo] Fix LISTITEM_PROPRTY for bool and integer properties. (PR:13875, 1 commit, 1 file changed)
  • [fix] handle favourites from Profile directory in FileManager (PR:13872, 1 commit, 1 file changed)
  • utils/Variant: use std::to_string() instead of std::ostringstream (PR:13870, 1 commit, 1 file changed)
  • LinuxRendererGLES: Fixed texture type for Mesa 18 compatibility (PR:13865, 1 commit, 1 file changed)
  • compile fix (const_iterator) (0bbbccb)
newclock5:
New commits in this build:
  • ffmpeg: hevc: Latest updates from Ben (6cf91202)
inputstream.adaptive (0bbbccb, +6), inputstream.rtmp (8920456, +1), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (098d23c), [url=https://github.com/kodi-pvr/pvr.filmon]pvr.filmon/url, pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (00d57de, +3), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (dbdc96e, +3), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (1244e14), vfs.libarchive (1b00b57, +1)
17.8-230, 15 May 2018: Based off OSMC commit (b9f8a720) and newclock5 (891e58)
XBMC:
  • VideoPlayer: add setting for using VAAPI HEVC (PR:13856, 3 commits, 3 files changed)
  • Use GetDynPath for getPlayingFile (PR:13874, 1 commit, 1 file changed)
  • BusyDialog: ignore gui messages while active (PR:13861, 1 commit, 11 files changed)
  • [PVR] CGUIWindowPVRBase multithreading fixes (PR:13879, 5 commits, 2 files changed)
  • Prefer stereo streams if user has configured 2.0 in AE (PR:13877, 1 commit, 4 files changed)
  • dialogs/GUIDialogBusy: stop the CThread properly (PR:13880, 1 commit, 1 file changed)
  • Revert ā€œBusyDialog: ignore gui messages while activeā€ (PR:13881, 1 commit, 11 files changed)
  • paplayer: only fire a single OnPlaybackStarted for a file (PR:13882, 1 commit, 3 files changed)
  • PVRClient: protect access to m_timertypes (PR:13883, 1 commit, 1 file changed)
  • [WV JNI] Hold Classloader open for OnEventListener to avoid GC cleanup (0da87a8)
pvr.dvbviewer:
  • Add support for guest privileges: (1d87501)
  • Bump version to 3.4.6 (98d7170)
  • Add custom timeout setting for livetv connections and timeshift (f9298c3)
  • Bump version to 3.4.7 (ac94e59)
pvr.vdr.vnsi:
  • client: delete cVNSI{Demux,Recording} on open error (PR:14, 1 commit, 1 file changed)
pvr.zattoo:
  • Persist zattoo session to prevent multiple logins (46f76a5)
  • Shorten session cookies in log (9cf0646)
  • Improve storing session cookie (bfeefe1)
  • Store uuid after generating (a410f2b)
newclock5:
  • Application: register Stereoscopicmanager for message target (891e5834)
inputstream.adaptive (0da87a8), inputstream.rtmp (8920456), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (ac94e59), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (00d57de), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (dbdc96e), pvr.vbox (3cf15ad), pvr.vdr.vnsi (ed1c124), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (a410f2b), vfs.libarchive (1b00b57)
Had issues with 230, when restarting the box, the system buzy icon shows all the time. Can’t do anything, tried mv.kodi kodi-backup to no avail. Doing a clean install to try.
I also saw that. Thought it was just my build. Pressed exit on my remote and it removed it. There are a pile of Busy Dialog/threading fixes in the next build which I think should fix this.
Just waiting for it to get published, saw it was on it’s way.
You might wait a while. :slight_smile: Vero builds have just finished, rbpi 1 & 2 builds just started, so another 4 hours on each build.
