[TESTING] New OSMC skin for Krypton
Beautiful skin! Looks very neat.
First minor issue I noticed: the overlay notification (for example “mounted removable storage ‘name of device’”) is too small, I am only able to read “mounted removable”, by the time it starts scrolling, the notification disappears.
This could be an issue when the notification states an error: you might not be able to read what causes the error.
Another issue for me: TV Shows> Fanart viewtype: the text of the tv show titles is too tiny, a bigger font would make it much better readable.
and a little feature request: the ability to use a folder containing photos (from the Pictures library) as background (perhaps only when not inside Movies or TV Shows or Music Videos sections).
The OSMC skin doesn’t have a ‘fanart’ view. Please double-check you’re using the new OSMC skin, and not Kodi’s new default skin Estuary :slight_smile:
Yesterday I upgraded to the latest Krypton Beta build for the first time (straight from stable OSMC) - Kodi 17 Beta7 came up with it’s new estuary skin, for some reason OSMC skin was not taken up.
Also, Kodi hang in “Migrating addons to the new version for hours”.
After a reboot, the system loaded with Kodi’s estuary sking and showed an error message “The addon MyOSMC is not compatible with Kodi 17 and has been disabled” (??)
First I manually changed the Skin to OSMC, that seems to be working OK.
Then I manually enabled the MyOSMC addon, it seems to work, it shows a circular interface with the familiar OSMC icons but with the old blue background, and the version shown is OSMC December 2016 2016.12-1, it doesn’t integrate well with the skin at all. Is this OK or for some reason the OSMC addon didn’t get updated?
The latest version is the December version so that is fine. The My OSMC interface is skin independent, to make sure that it looks the same regardless of the chosen skin.
It will get a visual refresh soon enough, but not in time for Krypton
I have just installed the beta and put the OSMC skin on. Its all working well so far except for the skin menu options.
I customised the menu system in the skin settings and now the menu options don’t show up. I have even gone into the settings and tried to re make the menus I wanted but it still doesn’t work. Anyone else having this problem?
To get a better understanding of the problem you are experiencing we need more information from you. The best way to get this information is for you to upload some logs. You can learn more about how to submit a useful support request here.
Just curious, does the new skin solve this “coloured artifact” problem?
(I have ignored / forgotten about the problem, but someone just replied in the thread and reminded me of it.)
I wasn’t aware of this problem.
If it exists with the new skin, let us know.
Press left button. All submenus go left now rather than right and are hidden while on the main gui. If this works you can also map the ok button to go left. Let me know and I’ll look up the command
Is there a way to align the EPG descriptions to the left instead of full justifying?
Not at this time, but maybe some improvements can be made in the future.
Just noticed something else, the progress bar that showed if the current tv show was at the beginning, middle or end is now gone. The time next to the current and next shows are useful but it’s just not as fast to tell.
On the other hand, I think it looks great like this. Maybe a pie chart next to the name of the channel/show could bring the progress back while still looking this clean.
I really should’ve tested and suggested this stuff earlier…
Can you take a photo or a drawing to demonstrate your proposal?
We are far from finished with the skin but wanted to wait for a wider testing base before making any further changes.
Rough sketch of what I meant.
The yellow/orange/golden also seems out of place in this menu, maybe keeping it white and bold to show that it’s selected is enough. Since the “scrolling selection” is bigger and centered on the screen I’d say it wouldn’t bring up any confusion.
And on a more personal note, the time not being always visible on the main menu when watching something is a bummer.
But this could be just me, since I don’t wear a watch and don’t have another one on my living room (apart from the computer and phone). It was just handy to hit back to see the time.
This is a very nice proposal. I’ll run it past @simonbrunton and @BobCrachett. I am sure Simon can do something with the colours that works well.
We could also use this watch progress indicator for Movies and TV Shows as well.
Nice suggestions. Keep them coming.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
