Yes I read the forum first. SSH’d in and ran the commands listed to recreate the ~/.kodi directory. Had no special skins, early release or that many addons.
OK – without any logs or anything, I can only speculate.
Happy to help, but depending on how much you would lose, a reinstall may be the easiest option. Info on how to perform a reinstall can be found at Reinstalling OSMC - Vero (late 2015) - OSMC
You go to Download - OSMC and download an installer for the PC which you use to write the image to the SD card. A recovery from within the Vero is not possible (unless you use specific command line tools).
When running the installer you choose Vero2 as the target device.
How much space do I need on the SD card? Wouldnt mind knowing the CLI method as well. Last question and I’ll stop bugging everyone, but I can’t use USB for a reinstall?
