My PC (192.168.1.1) has all my media on it.
I’m using Putty on my PC to do all of this.
i’ve just tried logging in to my vero using putty again and it says “updating APT cache. Please be patient.”
You can press CTRL + C to skip that. It’s something I added to update APT cache on first login, as users were frequently logging in to follow some tutorial and run some apt-get install command without running apt-get update first, then wondering why it didn’t work.
Okay, but it also seems that DHCP is configuring this PC as a DNS server, as your first output of resolv.conf showed /etc/resolv.conf to have 192.168.1.1 as the default nameserver. This suggests the PC is functioning as a DNS server, and possibly some sort of gateway.
What does /sbin/ifconfig show on the Vero 2, and what does it show on the Pi 2?
Also, you can use this icon to format big blocks of text (copy / paste etc) better:
sure will do.
cat /etc/resolv.conf
returns
nameserver 8.8.8.8
i’m not sure what my rpi2’s IP Address is and it isn’t appearing in the ARP table on my router gateway at the moment so i’ll have to check that physically on the rpi when i get home.
i’ll check what it has and try matching the settings on the vero to it if it differs.
Thanks heaps for your help so far btw.
No problem – interested in getting this solved for you.
ok wow i’m an idiot.
i must have got the rpi and vero confused (i switch hdmi cable back and forth) and tried to set the MAC address for the vero to 192.168.1.4 which is actually the rpi2!
I’ve now set the mac address for the rpi2 to its expected and set the mac address for the vero so 192.168.1.6
I ran
ifconfig
echo "nameserver 8.8.8.8" | sudo tee /etc/resolv.conf
sudo apt-get update
returned with
login as: osmc
osmc@192.168.1.6's password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Oct 20 21:58:48 2016 from jarrard-desktop.home.gateway
osmc@vero:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 08:61:60:11:20:90
inet addr:192.168.1.6 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:839 errors:0 dropped:1 overruns:0 frame:0
TX packets:492 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:259459 (253.3 KiB) TX bytes:62058 (60.6 KiB)
Interrupt:40
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
osmc@vero:~$ echo "nameserver 8.8.8.8" | sudo tee /etc/resolv.conf
nameserver 8.8.8.8
osmc@vero:~$ sudo apt-get update
Hit http://security.debian.org jessie/updates InRelease
Ign http://ftp.debian.org jessie InRelease
Hit http://ftp.debian.org jessie-updates InRelease
Hit http://security.debian.org jessie/updates/main armhf Packages
Hit http://security.debian.org jessie/updates/contrib armhf Packages
Hit http://ftp.debian.org jessie Release.gpg
Hit http://security.debian.org jessie/updates/non-free armhf Packages
Hit http://security.debian.org jessie/updates/contrib Translation-en
Get:1 http://ftp.debian.org jessie-updates/main armhf Packages/DiffIndex [5932 B]
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://apt.osmc.tv jessie InRelease
Hit http://security.debian.org jessie/updates/non-free Translation-en
Hit http://ftp.debian.org jessie-updates/contrib armhf Packages
Get:2 http://ftp.debian.org jessie-updates/non-free armhf Packages/DiffIndex [736 B]
Get:3 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Hit http://ftp.debian.org jessie-updates/contrib Translation-en
Get:4 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [2704 B]
Get:5 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Hit http://ftp.debian.org jessie/main armhf Packages
Hit http://ftp.debian.org jessie/contrib armhf Packages
Hit http://ftp.debian.org jessie/non-free armhf Packages
Hit http://ftp.debian.org jessie/contrib Translation-en
Ign http://apt.osmc.tv jessie/main Translation-en
Hit http://ftp.debian.org jessie/main Translation-en
Hit http://ftp.debian.org jessie/non-free Translation-en
Fetched 12.1 kB in 19s (618 B/s)
Reading package lists... Done
osmc@vero:~$ cat /etc/resolv.conf
nameserver 8.8.8.8
osmc@vero:~$
That looks much more healthy.
Can you try streaming some video now and let me know how that works? Also make sure you check for updates via My OSMC. I’m not sure how long your network hasn’t been working for but you’ll want to get the latest updates
it updated 1-2 days ago.
Just went to play finding dory, clicked “ok” on remote to bring up UI. clicked the “audio” button (wanted to turn passthrough back on, which is another issue) and the UI froze again.
clicked stop and nothing happened. eventually a few minutes later the UI just dissapeared and i could click stop.
here is the log.
You may want to check for updates again.
Linux vero 3.10.102-11-osmc #1 SMP Sun Oct 2 13:52:41 UTC 2016 armv7l GNU/Linux
See OSMC's October update is here - OSMC. An update was released about 12 hours ago.
ok i’ve done latest update and moved my music over to IP address SMB as well.
neither local nor network are causing issues atm. hopefully its not just intermittently working. i’ll keep you posted if it pops up again and let you know if i go for a while if it doesnt so this can be marked as solved.
I am glad to hear this.
If you have any further problems, you know where we’ll be ![]()
Unfortunately it’s still occuring.
Just watching Shameless US and had it freeze again.
I only can recommend once more, do a longer term (1 hour) iperf test between your PC and OSMC. Maybe with two different sessions one with iperf3 -t 3600 -c <192.168.1.1> from OSMC to the PC and at the same time one with iperf3 -t 3600 -c <192.168.1.6> from your PC to OSMC. You would need to start the server then first on your PC and OSMC with iperf3 -s
oh yeah! sorry forgot about that.
where do i actually type those commands?
typing iperf3 -t 3600 -c <192.168.1.1> logged onto my vero with putty returns
osmc@vero:~$ iperf3 -t 3600 -c <192.168.1.1>
-bash: syntax error near unexpected token `newline'
osmc@vero:~$
Sorry my mistake, I first wanted to write but then I digged out the info from the log so the commands would be.
iperf3 -siperf3 -siperf3 -t 3600 -c 192.168.1.1iperf3 -t 3600 -c 192.168.1.6As you might loose connectivity to the Vero during the test I suggest to execute the commands in seperate “screens”. Therefore install the screen application with sudo apt-get install screen first
sorry, what do you mean by “window on PC” and “Window on Vero”?
I just tried running iperf3 -s on Putty (logged into vero).
osmc@vero:~$ iperf3 -s
-bash: iperf3: command not found
osmc@vero:~$ sudo apt-get install
Building dependency tree
The following package was automatically installed and is no longer required:
vero2-image-3.10.102-11-osmc
Use 'apt-get autoremove' to remove it.
osmc@vero:~$
guessing i need to install iperf3 on the vero somehow first?
Well I would have guessed you did that two weeks ago when I recommended it
Obvisouly you need to install iperf on the Vero sudo apt-get install iperf3 and also on your PC iPerf - Download iPerf3 and original iPerf pre-compiled binaries
I mean a “terminal window” which e.g. your Putty session is one such terminal window.
ok ta. figured it out
ran a quick 2 minutes test (i was trying to get it working. i’ll run a 1 hour test overnight).
the vero only has a 100Mbs ethernet port doesnt it?
osmc@vero:~$ iperf3 -t 120 -c 192.168.1.1
Connecting to host 192.168.1.1, port 5201
[ 4] local 192.168.1.6 port 36549 connected to 192.168.1.1 port 5201
[ 4] 0.00-1.00 sec 10.0 MBytes 84.1 Mbits/sec 0 103 KBytes
[ 4] 1.00-2.00 sec 9.92 MBytes 83.3 Mbits/sec 0 105 KBytes
[ 4] 2.00-3.00 sec 9.87 MBytes 82.7 Mbits/sec 0 105 KBytes
[ 4] 3.00-4.00 sec 9.94 MBytes 83.4 Mbits/sec 0 105 KBytes
[ 4] 4.00-5.00 sec 9.84 MBytes 82.6 Mbits/sec 0 105 KBytes
[ 4] 5.00-6.00 sec 9.90 MBytes 83.0 Mbits/sec 0 106 KBytes
[ 4] 6.00-7.00 sec 9.93 MBytes 83.3 Mbits/sec 0 107 KBytes
[ 4] 7.00-8.00 sec 9.94 MBytes 83.3 Mbits/sec 0 112 KBytes
[ 4] 8.00-9.00 sec 9.90 MBytes 83.1 Mbits/sec 0 112 KBytes
[ 4] 9.00-10.00 sec 9.89 MBytes 83.0 Mbits/sec 0 113 KBytes
[ 4] 10.00-11.00 sec 9.93 MBytes 83.2 Mbits/sec 0 115 KBytes
[ 4] 11.00-12.00 sec 9.84 MBytes 82.5 Mbits/sec 0 115 KBytes
[ 4] 12.00-13.00 sec 9.99 MBytes 83.6 Mbits/sec 0 115 KBytes
[ 4] 13.00-14.00 sec 9.88 MBytes 83.0 Mbits/sec 0 120 KBytes
[ 4] 14.00-15.00 sec 9.84 MBytes 82.5 Mbits/sec 0 120 KBytes
[ 4] 15.00-16.00 sec 9.92 MBytes 83.2 Mbits/sec 0 124 KBytes
[ 4] 16.00-17.00 sec 9.89 MBytes 83.0 Mbits/sec 0 124 KBytes
[ 4] 17.00-18.00 sec 9.87 MBytes 82.8 Mbits/sec 0 124 KBytes
[ 4] 18.00-19.00 sec 9.96 MBytes 83.5 Mbits/sec 0 126 KBytes
[ 4] 19.00-20.00 sec 9.89 MBytes 83.0 Mbits/sec 0 127 KBytes
[ 4] 20.00-21.00 sec 9.82 MBytes 82.4 Mbits/sec 0 127 KBytes
[ 4] 21.00-22.00 sec 9.94 MBytes 83.4 Mbits/sec 0 127 KBytes
[ 4] 22.00-23.00 sec 9.86 MBytes 82.7 Mbits/sec 0 127 KBytes
[ 4] 23.00-24.00 sec 9.87 MBytes 82.8 Mbits/sec 0 132 KBytes
[ 4] 24.00-25.00 sec 9.93 MBytes 83.3 Mbits/sec 0 132 KBytes
[ 4] 25.00-26.00 sec 9.86 MBytes 82.7 Mbits/sec 0 132 KBytes
[ 4] 26.00-27.00 sec 9.93 MBytes 83.3 Mbits/sec 0 132 KBytes
[ 4] 27.00-28.00 sec 9.87 MBytes 82.8 Mbits/sec 0 134 KBytes
[ 4] 28.00-29.00 sec 9.92 MBytes 83.2 Mbits/sec 0 134 KBytes
[ 4] 29.00-30.00 sec 9.83 MBytes 82.5 Mbits/sec 0 134 KBytes
[ 4] 30.00-31.00 sec 9.94 MBytes 83.4 Mbits/sec 0 134 KBytes
[ 4] 31.00-32.00 sec 9.85 MBytes 82.6 Mbits/sec 0 137 KBytes
[ 4] 32.00-33.00 sec 9.90 MBytes 83.1 Mbits/sec 0 137 KBytes
[ 4] 33.00-34.00 sec 9.91 MBytes 83.1 Mbits/sec 0 137 KBytes
[ 4] 34.00-35.00 sec 9.90 MBytes 83.1 Mbits/sec 0 137 KBytes
[ 4] 35.00-36.00 sec 9.91 MBytes 83.1 Mbits/sec 0 137 KBytes
[ 4] 36.00-37.00 sec 9.82 MBytes 82.4 Mbits/sec 0 137 KBytes
[ 4] 37.00-38.00 sec 9.90 MBytes 83.0 Mbits/sec 0 137 KBytes
[ 4] 38.00-39.00 sec 9.91 MBytes 83.1 Mbits/sec 0 137 KBytes
[ 4] 39.00-40.00 sec 9.92 MBytes 83.2 Mbits/sec 0 137 KBytes
[ 4] 40.00-41.00 sec 9.89 MBytes 82.9 Mbits/sec 0 137 KBytes
[ 4] 41.00-42.00 sec 9.91 MBytes 83.1 Mbits/sec 0 137 KBytes
[ 4] 42.00-43.00 sec 9.82 MBytes 82.4 Mbits/sec 0 137 KBytes
[ 4] 43.00-44.00 sec 9.90 MBytes 83.1 Mbits/sec 0 137 KBytes
[ 4] 44.00-45.00 sec 9.91 MBytes 83.1 Mbits/sec 0 137 KBytes
[ 4] 45.00-46.00 sec 9.91 MBytes 83.1 Mbits/sec 0 137 KBytes
[ 4] 46.00-47.00 sec 9.86 MBytes 82.7 Mbits/sec 0 141 KBytes
[ 4] 47.00-48.00 sec 9.86 MBytes 82.7 Mbits/sec 0 141 KBytes
[ 4] 48.00-49.00 sec 9.93 MBytes 83.3 Mbits/sec 0 141 KBytes
[ 4] 49.00-50.00 sec 9.89 MBytes 83.0 Mbits/sec 0 144 KBytes
[ 4] 50.00-51.00 sec 9.85 MBytes 82.6 Mbits/sec 0 144 KBytes
[ 4] 51.00-52.00 sec 9.88 MBytes 82.9 Mbits/sec 0 144 KBytes
[ 4] 52.00-53.00 sec 9.97 MBytes 83.6 Mbits/sec 0 144 KBytes
[ 4] 53.00-54.00 sec 9.81 MBytes 82.3 Mbits/sec 0 144 KBytes
[ 4] 54.00-55.00 sec 9.96 MBytes 83.6 Mbits/sec 0 144 KBytes
[ 4] 55.00-56.00 sec 9.87 MBytes 82.8 Mbits/sec 0 148 KBytes
[ 4] 56.00-57.00 sec 9.87 MBytes 82.8 Mbits/sec 0 148 KBytes
[ 4] 57.00-58.00 sec 9.93 MBytes 83.3 Mbits/sec 0 153 KBytes
[ 4] 58.00-59.00 sec 9.85 MBytes 82.7 Mbits/sec 0 153 KBytes
[ 4] 59.00-60.00 sec 9.85 MBytes 82.6 Mbits/sec 0 153 KBytes
[ 4] 60.00-61.00 sec 9.96 MBytes 83.6 Mbits/sec 0 156 KBytes
[ 4] 61.00-62.00 sec 9.87 MBytes 82.8 Mbits/sec 0 156 KBytes
[ 4] 62.00-63.00 sec 9.90 MBytes 83.0 Mbits/sec 0 156 KBytes
[ 4] 63.00-64.00 sec 9.80 MBytes 82.2 Mbits/sec 0 156 KBytes
[ 4] 64.00-65.00 sec 9.88 MBytes 82.9 Mbits/sec 0 156 KBytes
[ 4] 65.00-66.00 sec 9.90 MBytes 83.1 Mbits/sec 0 156 KBytes
[ 4] 66.00-67.00 sec 9.93 MBytes 83.3 Mbits/sec 0 156 KBytes
[ 4] 67.00-68.00 sec 9.90 MBytes 83.0 Mbits/sec 0 158 KBytes
[ 4] 68.00-69.00 sec 9.82 MBytes 82.3 Mbits/sec 0 158 KBytes
[ 4] 69.00-70.00 sec 9.92 MBytes 83.2 Mbits/sec 0 160 KBytes
[ 4] 70.00-71.00 sec 9.90 MBytes 83.1 Mbits/sec 0 160 KBytes
[ 4] 71.00-72.00 sec 9.92 MBytes 83.2 Mbits/sec 0 160 KBytes
[ 4] 72.00-73.00 sec 9.82 MBytes 82.4 Mbits/sec 0 160 KBytes
[ 4] 73.00-74.00 sec 9.89 MBytes 82.9 Mbits/sec 0 161 KBytes
[ 4] 74.00-75.00 sec 9.89 MBytes 82.9 Mbits/sec 0 161 KBytes
[ 4] 75.00-76.00 sec 9.96 MBytes 83.5 Mbits/sec 0 161 KBytes
[ 4] 76.00-77.00 sec 9.88 MBytes 82.9 Mbits/sec 0 161 KBytes
[ 4] 77.00-78.00 sec 9.86 MBytes 82.7 Mbits/sec 0 163 KBytes
[ 4] 78.00-79.00 sec 9.88 MBytes 82.9 Mbits/sec 0 163 KBytes
[ 4] 79.00-80.00 sec 9.87 MBytes 82.8 Mbits/sec 0 164 KBytes
[ 4] 80.00-81.00 sec 9.96 MBytes 83.6 Mbits/sec 0 164 KBytes
[ 4] 81.00-82.00 sec 9.88 MBytes 82.8 Mbits/sec 0 164 KBytes
[ 4] 82.00-83.00 sec 9.88 MBytes 82.9 Mbits/sec 0 164 KBytes
[ 4] 83.00-84.00 sec 9.88 MBytes 82.9 Mbits/sec 0 164 KBytes
[ 4] 84.00-85.00 sec 9.88 MBytes 82.9 Mbits/sec 0 164 KBytes
[ 4] 85.00-86.00 sec 9.95 MBytes 83.5 Mbits/sec 0 164 KBytes
[ 4] 86.00-87.00 sec 9.89 MBytes 82.9 Mbits/sec 0 164 KBytes
[ 4] 87.00-88.00 sec 9.89 MBytes 83.0 Mbits/sec 0 164 KBytes
[ 4] 88.00-89.00 sec 9.88 MBytes 82.8 Mbits/sec 0 164 KBytes
[ 4] 89.00-90.00 sec 9.90 MBytes 83.1 Mbits/sec 0 164 KBytes
[ 4] 90.00-91.00 sec 9.85 MBytes 82.6 Mbits/sec 0 164 KBytes
[ 4] 91.00-92.00 sec 9.88 MBytes 82.9 Mbits/sec 0 164 KBytes
[ 4] 92.00-93.00 sec 9.90 MBytes 83.0 Mbits/sec 0 164 KBytes
[ 4] 93.00-94.00 sec 9.93 MBytes 83.3 Mbits/sec 0 165 KBytes
[ 4] 94.00-95.00 sec 9.82 MBytes 82.4 Mbits/sec 0 165 KBytes
[ 4] 95.00-96.00 sec 9.87 MBytes 82.8 Mbits/sec 0 165 KBytes
[ 4] 96.00-97.00 sec 9.95 MBytes 83.5 Mbits/sec 0 165 KBytes
[ 4] 97.00-98.00 sec 9.83 MBytes 82.5 Mbits/sec 0 165 KBytes
[ 4] 98.00-99.00 sec 9.92 MBytes 83.2 Mbits/sec 0 165 KBytes
[ 4] 99.00-100.00 sec 9.93 MBytes 83.3 Mbits/sec 0 165 KBytes
[ 4] 100.00-101.00 sec 9.90 MBytes 83.0 Mbits/sec 0 167 KBytes
[ 4] 101.00-102.00 sec 9.83 MBytes 82.4 Mbits/sec 0 167 KBytes
[ 4] 102.00-103.00 sec 9.94 MBytes 83.4 Mbits/sec 0 167 KBytes
[ 4] 103.00-104.00 sec 9.93 MBytes 83.3 Mbits/sec 0 167 KBytes
[ 4] 104.00-105.00 sec 9.88 MBytes 82.9 Mbits/sec 0 167 KBytes
[ 4] 105.00-106.00 sec 9.84 MBytes 82.5 Mbits/sec 0 167 KBytes
[ 4] 106.00-107.00 sec 9.92 MBytes 83.2 Mbits/sec 0 167 KBytes
[ 4] 107.00-108.00 sec 9.92 MBytes 83.2 Mbits/sec 0 167 KBytes
[ 4] 108.00-109.00 sec 9.86 MBytes 82.7 Mbits/sec 0 168 KBytes
[ 4] 109.00-110.00 sec 9.93 MBytes 83.3 Mbits/sec 0 168 KBytes
[ 4] 110.00-111.00 sec 9.82 MBytes 82.4 Mbits/sec 0 168 KBytes
[ 4] 111.00-112.00 sec 9.95 MBytes 83.5 Mbits/sec 0 168 KBytes
[ 4] 112.00-113.00 sec 9.88 MBytes 82.9 Mbits/sec 0 170 KBytes
[ 4] 113.00-114.00 sec 9.85 MBytes 82.6 Mbits/sec 0 170 KBytes
[ 4] 114.00-115.00 sec 9.89 MBytes 83.0 Mbits/sec 0 175 KBytes
[ 4] 115.00-116.00 sec 9.89 MBytes 82.9 Mbits/sec 0 175 KBytes
[ 4] 116.00-117.00 sec 9.98 MBytes 83.7 Mbits/sec 0 175 KBytes
[ 4] 117.00-118.00 sec 9.88 MBytes 82.9 Mbits/sec 0 175 KBytes
[ 4] 118.00-119.00 sec 9.82 MBytes 82.4 Mbits/sec 0 175 KBytes
[ 4] 119.00-120.00 sec 9.88 MBytes 82.9 Mbits/sec 0 175 KBytes
[ 4] 0.00-120.00 sec 1.16 GBytes 83.0 Mbits/sec 0 sender
[ 4] 0.00-120.00 sec 1.16 GBytes 83.0 Mbits/sec receiver
iperf Done.
osmc@vero:~$
yes, therefore your results looks correct.
But as mentioned it might break after a while so run it longer as you planned.
Also remember to have a second one running for the other direction as iperf is unidirectional.
ah ok i get you
struggling to copy over results from putty using my phone. here’s the PC Client side
[ 4] 3308.00-3309.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3309.00-3310.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3310.00-3311.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3311.00-3312.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3312.00-3313.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3313.00-3314.00 sec 11.1 MBytes 93.2 Mbits/sec
[ 4] 3314.00-3315.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3315.00-3316.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3316.00-3317.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3317.00-3318.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3318.00-3319.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3319.00-3320.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3320.00-3321.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3321.00-3322.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3322.00-3323.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3323.00-3324.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3324.00-3325.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3325.00-3326.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3326.00-3327.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3327.00-3328.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3328.00-3329.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3329.00-3330.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3330.00-3331.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3331.00-3332.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3332.00-3333.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3333.00-3334.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3334.00-3335.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3335.00-3336.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3336.00-3337.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3337.00-3338.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3338.00-3339.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3339.00-3340.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3340.00-3341.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3341.00-3342.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3342.00-3343.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3343.00-3344.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3344.00-3345.00 sec 10.8 MBytes 90.1 Mbits/sec
[ 4] 3345.00-3346.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3346.00-3347.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3347.00-3348.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3348.00-3349.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3349.00-3350.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3350.00-3351.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3351.00-3352.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3352.00-3353.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3353.00-3354.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3354.00-3355.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3355.00-3356.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3356.00-3357.00 sec 11.0 MBytes 92.1 Mbits/sec
[ 4] 3357.00-3358.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3358.00-3359.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3359.00-3360.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3360.00-3361.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3361.00-3362.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3362.00-3363.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3363.00-3364.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3364.00-3365.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3365.00-3366.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3366.00-3367.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3367.00-3368.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3368.00-3369.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3369.00-3370.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3370.00-3371.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3371.00-3372.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3372.00-3373.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3373.00-3374.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3374.00-3375.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3375.00-3376.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3376.00-3377.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3377.00-3378.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3378.00-3379.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3379.00-3380.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3380.00-3381.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3381.00-3382.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3382.00-3383.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3383.00-3384.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3384.00-3385.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3385.00-3386.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3386.00-3387.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3387.00-3388.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3388.00-3389.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3389.00-3390.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3390.00-3391.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3391.00-3392.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3392.00-3393.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3393.00-3394.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3394.00-3395.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3395.00-3396.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3396.00-3397.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3397.00-3398.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3398.00-3399.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3399.00-3400.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3400.00-3401.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3401.00-3402.00 sec 11.1 MBytes 93.2 Mbits/sec
[ 4] 3402.00-3403.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3403.00-3404.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3404.00-3405.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3405.00-3406.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3406.00-3407.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3407.00-3408.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3408.00-3409.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3409.00-3410.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3410.00-3411.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3411.00-3412.00 sec 10.8 MBytes 90.2 Mbits/sec
[ 4] 3412.00-3413.00 sec 11.1 MBytes 93.1 Mbits/sec
[ 4] 3413.00-3414.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3414.00-3415.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3415.00-3416.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3416.00-3417.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3417.00-3418.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3418.00-3419.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3419.00-3420.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3420.00-3421.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3421.00-3422.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3422.00-3423.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3423.00-3424.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3424.00-3425.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3425.00-3426.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3426.00-3427.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3427.00-3428.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3428.00-3429.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3429.00-3430.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3430.00-3431.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3431.00-3432.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3432.00-3433.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3433.00-3434.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3434.00-3435.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3435.00-3436.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3436.00-3437.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3437.00-3438.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3438.00-3439.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3439.00-3440.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3440.00-3441.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3441.00-3442.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3442.00-3443.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3443.00-3444.00 sec 11.1 MBytes 93.2 Mbits/sec
[ 4] 3444.00-3445.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3445.00-3446.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3446.00-3447.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3447.00-3448.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3448.00-3449.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3449.00-3450.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3450.00-3451.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3451.00-3452.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3452.00-3453.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3453.00-3454.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3454.00-3455.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3455.00-3456.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3456.00-3457.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3457.00-3458.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3458.00-3459.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3459.00-3460.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3460.00-3461.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3461.00-3462.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3462.00-3463.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3463.00-3464.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3464.00-3465.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3465.00-3466.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3466.00-3467.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3467.00-3468.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3468.00-3469.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3469.00-3470.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3470.00-3471.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3471.00-3472.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3472.00-3473.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3473.00-3474.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3474.00-3475.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3475.00-3476.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3476.00-3477.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3477.00-3478.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3478.00-3479.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3479.00-3480.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3480.00-3481.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3481.00-3482.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3482.00-3483.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3483.00-3484.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3484.00-3485.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3485.00-3486.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3486.00-3487.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3487.00-3488.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3488.00-3489.00 sec 10.6 MBytes 89.2 Mbits/sec
[ 4] 3489.00-3490.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3490.00-3491.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3491.00-3492.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3492.00-3493.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3493.00-3494.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3494.00-3495.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3495.00-3496.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3496.00-3497.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3497.00-3498.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3498.00-3499.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3499.00-3500.00 sec 10.6 MBytes 89.2 Mbits/sec
[ 4] 3500.00-3501.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3501.00-3502.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3502.00-3503.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3503.00-3504.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3504.00-3505.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3505.00-3506.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3506.00-3507.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3507.00-3508.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3508.00-3509.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3509.00-3510.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3510.00-3511.00 sec 11.1 MBytes 93.2 Mbits/sec
[ 4] 3511.00-3512.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3512.00-3513.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3513.00-3514.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3514.00-3515.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3515.00-3516.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3516.00-3517.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3517.00-3518.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3518.00-3519.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3519.00-3520.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3520.00-3521.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3521.00-3522.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3522.00-3523.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3523.00-3524.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3524.00-3525.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3525.00-3526.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3526.00-3527.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3527.00-3528.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3528.00-3529.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3529.00-3530.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3530.00-3531.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3531.00-3532.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3532.00-3533.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3533.00-3534.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3534.00-3535.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3535.00-3536.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3536.00-3537.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3537.00-3538.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3538.00-3539.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3539.00-3540.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3540.00-3541.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3541.00-3542.00 sec 11.1 MBytes 93.2 Mbits/sec
[ 4] 3542.00-3543.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3543.00-3544.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3544.00-3545.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3545.00-3546.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3546.00-3547.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3547.00-3548.00 sec 10.9 MBytes 91.2 Mbits/sec
[ 4] 3548.00-3549.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 3549.00-3550.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3550.00-3551.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3551.00-3552.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3552.00-3553.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3553.00-3554.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3554.00-3555.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3555.00-3556.00 sec 11.1 MBytes 93.2 Mbits/sec
[ 4] 3556.00-3557.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3557.00-3558.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3558.00-3559.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3559.00-3560.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3560.00-3561.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3561.00-3562.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3562.00-3563.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3563.00-3564.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3564.00-3565.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3565.00-3566.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3566.00-3567.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3567.00-3568.00 sec 11.1 MBytes 93.2 Mbits/sec
[ 4] 3568.00-3569.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3569.00-3570.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3570.00-3571.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3571.00-3572.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3572.00-3573.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3573.00-3574.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3574.00-3575.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3575.00-3576.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3576.00-3577.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3577.00-3578.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3578.00-3579.00 sec 10.9 MBytes 91.3 Mbits/sec
[ 4] 3579.00-3580.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3580.00-3581.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3581.00-3582.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3582.00-3583.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 4] 3583.00-3584.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3584.00-3585.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3585.00-3586.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3586.00-3587.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3587.00-3588.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3588.00-3589.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3589.00-3590.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3590.00-3591.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3591.00-3592.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3592.00-3593.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3593.00-3594.00 sec 11.1 MBytes 93.3 Mbits/sec
[ 4] 3594.00-3595.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3595.00-3596.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3596.00-3597.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3597.00-3598.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 4] 3598.00-3599.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 4] 3599.00-3600.00 sec 11.4 MBytes 95.5 Mbits/sec
[ 4] 0.00-3600.00 sec 38.6 GBytes 92.1 Mbits/sec sender
[ 4] 0.00-3600.00 sec 38.6 GBytes 92.1 Mbits/sec receiver
iperf Done.
E:\iperf\iperf-3.1.3-win64>
