I just recently purchased my Vero 2. I got it up and running as well as enabled the Transmission add-on and TVHeader from the AppStore. I also installed Sickrage via this walkthrough. All was working fine until I updated the system. It told me that Kodi would have to shut down to install the updates and I allowed it. The download and install of the update completed successfully at which point the system shut down. I unplugged it and plugged it back in to start up the Vero 2 and it came up with the âPlease stand byâ screen, but it wonât complete the boot process.
I have the OSMC remote, ethernet chord, wireless keyboard, and USB external drive plugged in as well as the HDMI cable. I tried unplugging eveything except the power cable, but it still doesnât complete the boot proccess. I tried to ssh into the system to see what is happening and it just returns with a âno route to deviceâ error.
Is there a way that I can restore my Vero 2 to factory settings? It is still using the preinstalled OSMC that came on the internal storage. I know how to flash an SD card with n00bs (which I used to use for my raspberry pi), but I canât figure out how to access the native storage to assess the situation. Also, if I put an SD card in the system with n00bs on it, the system doesnât do anything different at start up than has been previously mentioned.
You can flash the latest version of OSMC from osmc.tv/download on to an SD card. OSMC will then partition the native storage and restore everything.
Itâs possible that tutorial has made some unexpected changes. It seems to be a little bit old. If you follow it again, and still have problems, then youâll likely know what the culprit is.
Do I have to use a certain type of SD card? Should the card be inserted into the Vero 2 before powering it on or after? I have tried both and 3 different cards (mind you, they are older cards) but nothing seems to happen
Did you install using the official OSMC installer from osmc.tv/download?
Did you definitely select the âVero 2 imageâ
An SDHC card should be fine. Make sure itâs put in the SD slot which is the top opening on the side.
These sound like obvious points but just covering the basics. If this doesnât work â no problem. First step would be to check that the SD card is being read.
Add a random file called âblah.zipâ (must have ZIP extension), can be an empty file
Find a non-conductive pin
Hold it in as Vero 2 is booting
Wait until you see a picture of an Android
Go to Apply update from EXT
Choose SD card
Do you see âblah.zipâ?
Before powering it on, so the installer can be read and loaded in to RAM.
Bottom port indeed. I was meaning to say not the top port.
A non conductive pin, i.e. not metal, could be a toothpick. There is a switch inside the audio port nearest the HDMI. You can click this with a thin, non-conductive pin.
You should do this while booting and you will get a Recovery screen. Then you can verify if the SD card is being read by following the steps above.
Sounds like the kernel is not being loaded if thatâs all that is on the screen. It can get corrupted if power is lost during the update process.
I tried hold pushing the button with a toothpick and holding it in place while plugging in the Vero 2. It still comes up with the same. âPlease stand byâ screen. I help the pin down for over a minute without any change. (I did hear and feel that the button was being pushed, so I know I am doing that part right.) I tried this with both the SD card in and out. No change.
Okay, this is quite odd. Hereâs something you can try
Put the SD card in a computer
Rename âkernel.imgâ, to ârecovery.imgâ.
Put SD card back in
Even without holding a toothpick in, if the card is correctly formatted, and the bootloader canât load the kernel on the internal storage, it should load this kernel as an emergency. You can also try holding the toothpick in to force it to load from the external storage immediately.
This seemed to fix the problem. Is the system now installed on the SD Card or is it on the internal HD? Can I remove the SD card, and if so how and when can I do that safely?
The system doesnât shut down after installing updates, it either just relaunches Kodi, or if certain updates were installed such as a kernel it automatically reboots, although the screen may remain blank a few seconds before it reboots.
It sounds like you may have actually unplugged the power while it was still in the middle of shutting down before rebooting, which may have lead to file system corruption that caused the problem.
Itâs important not to pull out the power during the update process so next time if nothing seems to be happening give it a few more minutes just to make sure and pull the power out as a last resort.
I tried rebooting the device, taking the card out and booting it up again, but the system would not boot.
The readout I get is:
Looking for root file system device /dev/vero-nand/root
FATAL ERROR: could not find root file system device /dev/vero-nand/root - if this is a USB install please check the USB drive is connected.
Osmc intramuscular Rescue Console.
For help and support see http://osmc.tv/help
I tried reinstalling the whole system via the SD card and did not remove the card on reboot, but it still comes up with the same error on any subsequent boot attempts. I have tried this with a fresh install as well as with some addons activated, and it doesnât seem to make a difference.
For now, I have disabled updates so that system never tries to reboot, but it I ever want to turn the system off, I basically have to restart from scratch.
Is there a way to use the rescue console that comes up to find the file system properly and get it to boot normally?
A reinstall works until I reboot the device. I am using all the official hardware. The only thing that is plugged in other than that is my usb external Hard drive. I have also tried booting with the harddrive unplugged. Makes no difference. Everything I reinstall I use the guidelines above. I put the kernel.img file on the SD card, rename it to recovery, and boot while pushing the pin in with a toothpick. I canât get it to properly recognize the SD card and reinstall unless I do all of these.
Yes, it goes through the whole installation process without any problems. I just canât shut down the device after a fresh install or it will give me the above error
I tried a fresh reset just now. I have always done an initial update before trying to reboot in my previous attempts. This time I just went through the initial set-up (picking the language, agreeing to terms of service etc.) and got to the main menu. I selected âPower off deviceâ and it hangs when shutting down. The screen read out is as follows:
Starting LSB: Start MTP daemonâŚ
] Started LSB: Start MTP daemon.
] Reached target Multi-User System.
] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel ChangesâŚ
] Started Update UTMP about System Runlevel Changes.
After 10 minutes of waiting, I unplugged the device, waited 30 seconds, and plugged it back in. It booted up just fine.
After this I tried taking the SD card out after unplugging it, and it still booted up fine (also still hangs on shut down.)
After this I did the initial update like I have done in the past by going to My OSMC -> Updates -> Manual Settings -> Search for Updates. After the update is applied and the system automatically restarts, it give the same error as before âcould not find root filesystemâŚâ etc. This time, however, the SD card I used to recover the Vero 2 is not in the device. This update seems to be causing the issue.
I will go ahead and reinstall as before, but not do the initial update (as this appears to work from the test that I just did) and I will keep updates off. It is still intriguing, however, that the system still hangs when trying to shutdown without doing this initial update.
We need to know what version you loaded on the SD. If you install 2016.06-2 (from osmc.tv), you should be up to date already. You will see the OSMC version in the bottom left of My OSMC.
Possibly an older version of OSMC where text stayed on screen post-halt. Not a fault, but not the best way to tell the user itâs safe to pull the plugâŚ
