Hi. I have a Vero 4K+ that I turn on the Wi-Fi and the status goes from “Disabled” to “No Wireless Connection” in around 18 seconds (takes too long). Then the box at the right does not display any SSID to connect to. It’s completely blank.
Okay. I’d try a cold boot and the connmanctl approach. You could create a WiFi hotspot on your phone, verify your other devices can see it, then see if the device sees it.
Created a hotspot on my phone. Then unplugged Vero, plugged it back in. Attached a keyboard and selected power → exit to enter command prompt. Then this is what I typed and responses
