Vero 4K+ ISO 3D MVC 24p framepacking can't play -> fixed
Please, help me to play 3D MVC 1080p 24p framepaking.
Vero 4K+ connected by Yamaha RX-V585 with Optoma HD39Darbee
Its played perfect in 2D, but when i try to switch to 3D i have problem.
I have 3 otions:
SideBySide - see half of picture in 24p Optoma mode
OverUnder - see half of picture in 24p Optoma mode
AsSource - Optoma switch to 50p mode and i see black screen.
It seems that Optoma does not understand 24p framepacking?
Please help.
Blu-ray Disc
ISO
Blu-Ray3D
MVC, AVC
MPEG-4 AVC Video 26501 kbps 1080p / 23,976 fps / 16:9 / High Profile 4.1
MPEG-4 MVC Video 17962 kbps
Disc Size: 5 826 950 518 bytes
Protection: AACS
BD-Java: No
Extras: Blu-ray 3D
BDInfo: 0.5.8
PLAYLIST REPORT:
Length: 1:28:50.992 (h:m:s.ms)
Size: 37 572 495 360 bytes
Total Bitrate: 56,38 Mbps
VIDEO:
Codec Bitrate Description
Hi there,
Unfortunately we’ve had to remove your thread from public viewing because it mentions a pirate addon, repository or website. We cannot provide any support for piracy. You should seek support from the developer of the addon or provider of the repo.
To get a better idea of our piracy policy, please see this link here FAQ - OSMC Forums You are welcome to edit your post and request for it to be re-listed at anytime. Do not simply duplicate the post.
Thank you for your understanding
Once you fix your post, we will also need more information, like logs.
Sorry, i removed source
Great, now please post logs.
Thank you for fast ansver. This is Vero 4K+. I will try to make logs
Can i do this from Kodi skin?
Yes, it works from any skin.
logs https://paste.osmc.tv/anagivuror
i opened 3d movie and choose “as movie”
it seems, that movie was played as SideBySide - because Optoma detected 3D and show left and right eye as half of the picrture.
After I switched to OverUnder - I see black screen Optoma and it reported 1080p 50hz.
i was forced to stop movie to back to menu.
there is no item in 3D menu - framepacking. only SideBySide and OverUnder.
You need to using Kernel 4.9 and Mediacenter 18.6 for proper 3D playback. Check this thread.
I found! In process
After updating with thread instructions - sutiation is the same. After i start 3D video in “Same as movie” - i got Optoma in 1080p 50Hz mode and black screen.
Log : https://paste.osmc.tv/lilotalata
vero3-mediacenter-osmc 18.7.1-5
The issue is now that you are on 18.7. You would need to downgrade to 18.6 which may not work as you had been on 18.5 before the upgrade.
already doing “sudo apt-get install --reinstall vero3-mediacenter-osmc=18.6.0-13”
what is “Sam” mean? is it important?
That is in the next line in the original post not part of the command.
Right command is sudo apt-get install --reinstall vero3-mediacenter-osmc=18.6.0-13 but I guess you get an error as you never had that version installed.
Downgrade successfulll - let me test 3D…
Timtout - now my HDMI cable die… Need to replace…
Its worked… Thank you for support. Appeared 3D type menu item “Hardware based”.
Frankly speaking 3D ISO MVC was the only thing why i have purchased Vero 4K+.
And now its work.
Thanks.
