Add the following line: deb http://apt.osmc.tv stretch-devel main
If this doesn’t work – don’t be disheartened. I can promptly give you downgrade instructions; but I’d like to get some logging info from your first.
OK, it’s done:
vero364-image-3.14.29-128-osmc:arm64
base-files curl dirmngr fuse gnupg gnupg-agent gpgv hdparm libconfuse-common
libconfuse1 libcurl3 libfuse2 libgnutls30 libnss-myhostname libpam-systemd
libseccomp2 libsystemd0 libtirpc1 libudev1 libx11-6 libx11-data libx11-xcb1
mediacenter-skin-osmc systemd systemd-sysv udev vero3-mediacenter-osmc
vero364-kernel-osmc:arm64 wpasupplicant
29 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 94.6 MB of archives.
After this operation, 243 MB of additional disk space will be used.
After it rebooted, I got the sad face logo - this actually happens every month after each upgrade, so i’ll ignore that.
I’ll report back to let you know whether the problem persists.
Hmm, this sounds similar to an issue (except I was having it with playing video files off my own server) I had over the weekend which I mentioned here:
