I just got a Raspberry Pi 4 to test out using it as a media center, primarily for Netflix, Disney+, Spotify, etc. I’m currently running into network issues.
According to System Info, I’m running OSMC using KODI 19.4. This was loaded onto the SD card via the Raspberry Pi Imager a day or two ago. I ran through basic initial setup but otherwise it is default settings.
When I go into My OSMC > Network > Wireless I can see my 2.4 GHz with an x, a lock, and 4 white dots (4 out of 5 bars of service?).
Issue 1
I cannot see my 5 GHz network. It appears as though R-PI 4 should have the capability to do this unless I am mistaken. Is there something I’m missing or need to configure?
Issue 2
When I try to connect to the 2.4 GHZ network it prompts for a password. It notes “Configuring…” for a while before displaying a Connection Failed message with status stating no wireless connection. I’m using a Logitech wireless keyboard as input but have entered the PW using both the letter keys and navigating the on-screen keyboard.
