Zero W
Did the upgrade to 4.4.27-10 osmc + kernel upgrade, then reboot.
I still cannot see both the Wireless and Bluetooth option in the MyOSMC Network section.
As you proposed, it might be useful for you to get access to my Pi Zero W remotely using SSH, in this case I would just need you to provide me the public IP I have to authorize in my FW.
All logs available in http://paste.osmc.io/alanomiyub .
Cheers.
I know what it will be…
DT missing for Zero W.
Will let you know when I have something ready
Okay, can you try and upgrade again?
The Device Tree for Pi0 was missing, so the WiFi / BT stack wasn’t being loaded, despite the driver now being present.
I have been able to connect to my network over Wifi. Using the procedure:
Login via the command line22
Edit the file /etc/apt/sources.list
Add the following line: deb http://apt.osmc.tv jessie-devel main
that you listed above. Thanks!
I can confirm the same as wingman4ce3d, the update has worked and I am now on wifi on my Zero W.
Bluetooth works OK too?
Can you enable it and see if your phone is picked up etc?
I just went through the same update procedure as wingman4ce3d, starting with a fresh Febuary 2017 base image. I can also confirm that the built in WIFI is now working just fine! However I do not see a bluetooth option in the networking screen inside MyOSMC. Is there something else needed to make that appear? I have uploaded my logs if thats helpfull to http://paste.osmc.io/ovicefapak
Try updating again.
Sadly no luck. I got 2 updates after another apt-get update&&apt-get dist-upgrade but still no bluetooth option under MyOSMC/Networking. Latest logs http://paste.osmc.io/kodamiwami.
What’s the output of
dpkg -l | grep base-files-osmc. It should be 2.1.0
sudo systemctl status brcm43xx.service
sudo systemctl status bt-firmware.path
Output of all 3 commands.
osmc@osmcpictureframe:~$ dpkg -l | grep base-files-osmc
ii  base-files-osmc                      2.1.0                       all                                                            modified base-files for OSMC system
osmc@osmcpictureframe:~$ sudo systemctl status brcm43xx.service
* brcm43xx.service - Broadcom 43xx bluetooth HCI
   Loaded: loaded (/lib/systemd/system/brcm43xx.service; disabled)
   Active: failed (Result: exit-code) since Fri 2017-03-17 00:25:58 EDT; 13min ago
  Process: 298 ExecStart=/usr/bin/rpi-btuart (code=exited, status=1/FAILURE)
Mar 17 00:25:58 osmcpictureframe rpi-btuart[298]: Can't set line discipline: Invalid argument
Mar 17 00:25:58 osmcpictureframe rpi-btuart[298]: Can't initialize device: Invalid argument
Mar 17 00:25:58 osmcpictureframe rpi-btuart[298]: bcm43xx_init
Mar 17 00:25:58 osmcpictureframe rpi-btuart[298]: Flash firmware /etc/firmware/BCM43430A1.hcd
Mar 17 00:25:58 osmcpictureframe rpi-btuart[298]: Set Controller UART speed to 3000000 bit/s
Mar 17 00:25:58 osmcpictureframe systemd[1]: brcm43xx.service: control process exited, code=exited status=1
Mar 17 00:25:58 osmcpictureframe systemd[1]: Failed to start Broadcom 43xx bluetooth HCI.
Mar 17 00:25:58 osmcpictureframe systemd[1]: Unit brcm43xx.service entered failed state.
osmc@osmcpictureframe:~$ sudo systemctl status bt-firmware.path
* bt-firmware.path - sdio device path monitor
   Loaded: loaded (/lib/systemd/system/bt-firmware.path; enabled)
   Active: active (waiting) since Fri 2017-03-17 00:25:48 EDT; 13min ago
Mar 17 00:25:48 osmcpictureframe systemd[1]: Starting sdio device path monitor.
Mar 17 00:25:48 osmcpictureframe systemd[1]: Started sdio device path monitor.
That’s good, looks like WiFi and BT are now being detected as expected, but the hciattach command is failing.
On Pi Zero W, we run this command:
/usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow -
which seems to be failing from your logs above.
Can you try running that command manually, and can you paste the output of ls -l /dev/serial1.
It would also be interesting to know if /usr/bin/hciattach /dev/serial1 bcm43xx 921600 noflow - works.
The three commads output
osmc@osmcpictureframe:~$ /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow -
bcm43xx_init
^C
osmc@osmcpictureframe:~$ ls -l /dev/serial1
lrwxrwxrwx 1 root root 7 Mar 17 00:25 /dev/serial1 -> ttyAMA0
osmc@osmcpictureframe:~$ /usr/bin/hciattach /dev/serial1 bcm43xx 921600 noflow -
bcm43xx_init
^C
osmc@osmcpictureframe:~$ ^C
I had to terminate the hciattach with ctrl-c after waiting about 10 seconds do get back to the shell.
Its quite late nere so I dont think I can do much more tonight. Hope this helps.
Interestingly, you don’t seem to get any error when running that command manually. There may be a timing issue or some problem with the script.
Also worth knowing if running sudo systemctl start bt-firmware.path works.
We’ll pick this up tomorrow
Looks like that works.
osmc@osmcpictureframe:~$ sudo systemctl start bt-firmware.path
   Active: active (waiting) since Fri 2017-03-17 00:25:48 EDT; 2h 31min ago
Mar 17 02:56:30 osmcpictureframe systemd[1]: Started sdio device path monitor.
I went back into MyOSMC/Network after running that but did not see Bluetooth.
Good night. Hope this all helps.
What is the output of sudo systemctl status bt-firmware.path after running start on bt-firmware.path?
Let me know if you want anything additional tested.
WiFi and Bluetooth support is now fully working in the jessie-devel repository.
I would like to thank @uTROT for providing SSH access to his Pi Zero, as well as those who offered SSH access for testing. This allowed me to do some testing remotely and it’s very appreciated. Please hit us up for some stickers and goodies :slight_smile:
It looks like WiFi and BT will be working for the new Pi Zero W in the next OSMC update, which will be available on Sunday.
Thank you for your patience
Thank you for this. Connectivity is working well though I have found an issue with using the internal Bluetooth with the a2dp app and the audio seems choppy. I’ve uploaded the logs to the a2dp thread. Thank you once again for the speedy update.
I have replied to your A2DP thread.
This is a known limitation of the internal adapter. Get a good adapter if you want reliable audio streaming. Support for the internal adapter may improve in the future.
