I am using a 2017 vizio m55-e0 and am having issues with HDR. Within the OSMC menu everything is vibrant but whenever a 4k hdr movie is played it is dim and washed out. I have HDR turned on and HDR 10 is confirmed according to the info overlay with the television.
I don’t know the answer, but from the mediainfo, kodi should be converting that file to RGB. There are some commandline incantations which may help, @sam_nazarko knows which ones work with the latest OSMC release.
I am not sure when that would have been. I did order my vero 4k right around that time. Would backing up my current install and reinstalling possibly help?
This sound very much like a tone-mapping issue. Many people report that HRD looks dim on their sets. I believe this comes from the fact that HDR material is graded for a given peak brightness and when the display cannot reach these peaks, brightness levels for most of the content of the media will look dim. It might also be that you must select HDR mode manually (that the TV does not autodetect HDR-content). I do not know the exact details, but you should research HDR tone-mapping. I do not think that the set is damaged/broken. Many people report the same problems from HDR players/disc. It is just poor implementation of the technology.
I tested HDR out on PS4 on Horizon Zero Dawn and I could notice quite a difference when turning HDR on and off. So could there be some sort of issue related with HDR between kodi or vero with my specific TV?
