Are there any updates?
At this time I’m holding kernel version 4.14.78-4-osmc, but I would like to update again…
Unfortunately I don’t have any HifiBerry hardware to test
I will update the kernel again in a couple of weeks, which will hopefully resolve the issue nonetheless.
For your information I had a similar issue after October update. Hifiberry card was shown as an output audio device but not in passthrough. I followed the instructions from HiFiBerry Digi under kernel 4.19.x working without patching Kodi source? and it worked fine to me.
Basically you need to add the card usr/share/alsa/cards/RPi-WM8804.conf (https://raw.githubusercontent.com/LibreELEC/LibreELEC.tv/master/projects/RPi/filesystem/usr/share/alsa/cards/RPi-WM8804.conf) that is gone after upgrade. Once it is added, reboot raspberry and Hifiberry will be available in passthrough.
I hope next OSMC update will keep this config card file!
Alfonso
To be honest, I’ve stopped using OSMC at this moment and switched to RetroPie with Kodi, where this isn’t a problem at all and which can be used with a RPi 4 in beta-release.
Hi @sam_nazarko,
Has It solved with the last kernel of january update?
No - but I will produce a new kernel this week and update this thread.
Hi @sam_nazarko! Is there any news?
Not yet – no.
With the new update the issue is corrected?
No - there is no new kernel yet. This thread will be updated when there is something to test.
It worked for me. Thanks.
Hopefully the issue is now addressed with the following commit:
/etc/apt/sources.list
Ok @sam_nazarko and @JanS
Excuse me…which is the command to edit the file /etc/apt/sources.list ?
sudo nano /etc/apt/sources.list
hi
i had osmc october 2019 2019.10-1
and now i’ve got osmc March 2020 2020.03-1.
in System/Audio i’ve chosed Alsa: snd_rpi_hifiberry_digi,S/PDIF in Audio output device
i have allowed passthrough and i’ve chosed "ALSA: snd_rpi_hifiberry_digi,S/PDIF in Passthrough device and i’ve allowed AC3 and DTS.
The audio now works! Great Job!
But… i think that a problem of my Onkyo audio amplifier…when start film, before, i have to turn off/on amplifer to listen the sound of film. Or is it a not correct setting in System Audio in OSMC?
thanks
Bye
The explanation of your problem is not clear. Can you elaborate please.
ok.
The audio card of RaspPi is connected by digital cable to Onkyo amplifer.
When i play film on OSMC I don’t hear any sound THEREFORE I turn off and turn on the onkyo amplifer and after i can hear the sound of the film.
Bye
can you post logs please
