Hi guys,
I’ve just installed the Netflix plugin but can’t get it working!
Here there is the log portion while trying to start the plugin:
2019-06-11 21:30:32.940 T:1644024544 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
2019-06-11 21:30:32.940 T:1644024544 DEBUG: PushCecKeypress - added key b
2019-06-11 21:30:32.948 T:1915516464 DEBUG: HandleKey: 11 (0x0b, obc244) pressed, action is Select
2019-06-11 21:30:32.950 T:1915516464 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflix/)
2019-06-11 21:30:32.950 T:1915516464 DEBUG: ParentPath = [addons://sources/video]
2019-06-11 21:30:32.952 T:1771111136 DEBUG: Thread waiting start, auto delete: false
2019-06-11 21:30:33.052 T:1915516464 DEBUG: ------ Window Init (DialogBusy.xml) ------
2019-06-11 21:30:33.086 T:1644024544 DEBUG: PushCecKeypress - received key b duration 146 (rep:0 size:0)
2019-06-11 21:30:33.086 T:1644024544 DEBUG: PushCecKeypress - ignored key b
2019-06-11 21:30:33.378 T:1762718432 DEBUG: CAddonDatabase::SetLastUsed[plugin.video.netflix] took 428 ms
2019-06-11 21:30:33.380 T:1771111136 DEBUG: StartScript - calling plugin Netflix(‘plugin://plugin.video.netflix/’,‘1’,’’,‘resume:false’)
2019-06-11 21:30:33.380 T:1791984352 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-06-11 21:30:33.381 T:1791984352 INFO: initializing python engine.
2019-06-11 21:30:33.381 T:1791984352 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.netflix/addon.py): start processing
2019-06-11 21:30:33.694 T:1791984352 DEBUG: -->Python Interpreter Initialized<–
2019-06-11 21:30:33.694 T:1791984352 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.netflix/addon.py): the source file to load is “/home/osmc/.kodi/addons/plugin.video.netflix/addon.py”
2019-06-11 21:30:33.696 T:1791984352 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.netflix/addon.py): setting the Python path to /home/osmc/.kodi/addons/plugin.video.netflix:/home/osmc/.kodi/addons/script.module.addon.signals/lib:/home/osmc/.kodi/addons/script.module.certifi/lib:/home/osmc/.kodi/addons/script.module.chardet/lib:/home/osmc/.kodi/addons/script.module.idna/lib:/home/osmc/.kodi/addons/script.module.inputstreamhelper/lib:/home/osmc/.kodi/addons/script.module.kodi-six/libs:/home/osmc/.kodi/addons/script.module.requests/lib:/home/osmc/.kodi/addons/script.module.urllib3/lib:/usr/lib/kodi/addons/script.module.pycryptodome/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
2019-06-11 21:30:33.696 T:1791984352 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.netflix/addon.py): entering source directory /home/osmc/.kodi/addons/plugin.video.netflix
2019-06-11 21:30:33.696 T:1791984352 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.netflix/addon.py): instantiating addon using automatically obtained id of “plugin.video.netflix” dependent on version 2.25.0 of the xbmc.python api
2019-06-11 21:30:36.515 T:1791984352 DEBUG: CAddonSettings[plugin.video.netflix]: loading setting definitions
2019-06-11 21:30:36.515 T:1791984352 DEBUG: CAddonSettings[plugin.video.netflix]: trying to load setting definitions from old format…
2019-06-11 21:30:36.519 T:1791984352 DEBUG: CAddonSettings[plugin.video.netflix]: loading setting values
2019-06-11 21:30:36.520 T:1791984352 DEBUG: CSettingsManager: requested setting (logging) was not found.
2019-06-11 21:30:36.523 T:1791984352 DEBUG: [Netflix] Started (Version 0.13.22)
2019-06-11 21:30:36.524 T:1791984352 DEBUG: [Netflix] “Navigation::router” called with arguments :paramstring = :
2019-06-11 21:30:36.524 T:1791984352 DEBUG: [Netflix] “Navigation::before_routing_action” called with arguments :params = {}:
2019-06-11 21:30:36.538 T:1791984352 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class ‘urllib2.URLError’>
Error Contents: <urlopen error [Errno 111] Connection refused>
File “/home/osmc/.kodi/addons/plugin.video.netflix/addon.py”, line 33, in
NAVIGATION.router(paramstring=REQUEST_PARAMS)
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/utils.py”, line 60, in wrapped
result = func(*args, **kwargs)
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/Navigation.py”, line 123, in router
options = self.before_routing_action(params=params)
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/Navigation.py”, line 867, in before_routing_action
‘method’: ‘is_logged_in’}))
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/Navigation.py”, line 1053, in call_netflix_service
data = urllib2.urlopen(full_url).read()
File “/usr/lib/python2.7/urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “/usr/lib/python2.7/urllib2.py”, line 429, in open
response = self._open(req, data)
File “/usr/lib/python2.7/urllib2.py”, line 447, in _open
‘_open’, req)
File “/usr/lib/python2.7/urllib2.py”, line 407, in _call_chain
result = func(*args)
File “/usr/lib/python2.7/urllib2.py”, line 1228, in http_open
return self.do_open(httplib.HTTPConnection, req)
File “/usr/lib/python2.7/urllib2.py”, line 1198, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 111] Connection refused>
–>End of Python script error report<–
2019-06-11 21:30:36.538 T:1791984352 DEBUG: onExecutionDone(4, /home/osmc/.kodi/addons/plugin.video.netflix/addon.py)
2019-06-11 21:30:36.609 T:1915516464 DEBUG: ------ Window Init (DialogNotification.xml) ------
2019-06-11 21:30:36.695 T:1791984352 WARNING: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.netflix/addon.py): the python script “/home/osmc/.kodi/addons/plugin.video.netflix/addon.py” has left several classes in memory that we couldn’t clean up. The classes include: N9XBMCAddon9xbmcaddon5AddonE
2019-06-11 21:30:36.696 T:1791984352 INFO: Python interpreter stopped
2019-06-11 21:30:36.696 T:1791984352 DEBUG: Thread LanguageInvoker 1791984352 terminating
2019-06-11 21:30:36.713 T:1771111136 ERROR: GetDirectory - Error getting plugin://plugin.video.netflix/
2019-06-11 21:30:36.714 T:1771111136 DEBUG: Thread waiting 1771111136 terminating
2019-06-11 21:30:36.714 T:1915516464 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2019-06-11 21:30:36.715 T:1915516464 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflix/) failed
2019-06-11 21:30:36.715 T:1915516464 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video)
2019-06-11 21:30:36.715 T:1915516464 DEBUG: ParentPath =
2019-06-11 21:30:36.716 T:1771111136 DEBUG: Thread waiting start, auto delete: false
2019-06-11 21:30:36.733 T:1771111136 DEBUG: Thread waiting 1771111136 terminating
2019-06-11 21:30:36.736 T:1771111136 DEBUG: Thread BackgroundLoader start, auto delete: false
2019-06-11 21:30:36.740 T:1915516464 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘noop’
2019-06-11 21:30:36.750 T:1771111136 DEBUG: Thread BackgroundLoader 1771111136 terminating
2019-06-11 21:30:41.943 T:1915516464 DEBUG: ------ Window Deinit (DialogNotification.xml) ------
2019-06-11 21:31:03.379 T:1762718432 DEBUG: Thread JobWorker 1762718432 terminating (autodelete)
2019-06-11 21:31:03.380 T:1663005408 DEBUG: Thread JobWorker 1663005408 terminating (autodelete)
Thanks!
