sudo -s
apt-get update
apt-get install rtorrent screen
cd /etc/ssl/certs
wget --no-check-certificate https://www.geotrust.com/resources/root_certificates/certificates/Equifax_Secure_Global_eBusiness_CA-1.cer
mv Equifax_Secure_Global_eBusiness_CA-1.cer Equifax_Secure_Global_eBusiness_CA-1.pem
c_rehash
mkdir -p ~/torrents/watch
mkdir -p ~/torrents/incomplete
mkdir -p ~/torrents/complete
touch ~/.rtorrent.rc
nano ~/.rtorrent.rc
a simple default config is provided here if you dont like the options change them to your preferance before adding them in your system
# This is an example resource file for rTorrent. Copy to
# ~/.rtorrent.rc and enable/modify the options as needed. Remember to
# uncomment the options you wish to enable.
# Maximum and minimum number of peers to connect to per torrent.
min_peers = 1
max_peers = 100
# Same as above but for seeding completed torrents (-1 = same as downloading)
min_peers_seed = 1
max_peers_seed = 50
# Maximum number of uploads single torrent may use
max_uploads = 10
# Maximum number of simultaneous downloads
max_downloads_global = 10
# Maximum number of simultaneous uploads
max_uploads_global = 20
# Global upload and download rate in KiB. "0" for unlimited.
download_rate = 0
upload_rate = 0
# Default directory to save the downloaded torrents.
directory = ~/torrents
# Default session directory. Make sure you don't run multiple instance
# of rtorrent using the same session directory. Perhaps using a
# relative path?
session = ~/torrents/.rsession
# Watch a directory for new torrents, and stop those that have been
# deleted.
schedule = watch_directory,5,5,load_start=~/torrents/watch/*.torrent
schedule = tied_directory,6,5,start_tied=
schedule = untied_directory,7,5,stop_untied=
# Close torrents when diskspace is low.
schedule = low_diskspace,5,60,close_low_diskspace=2000M
# Periodically save session data
schedule = session_save,240,300,session_save=
# Enable the default ratio group.
# ratio.enable=
# Change the limits, the defaults should be sufficient.
# Upload to a minimum ratio of 4.0
# ratio.min.set=400
# Upload to a maximum ratio of 20.0
# ratio.max.set=2000
# Upload a minimum of 250 MB
# ratio.upload.set=250M
# When seeding ratio is reached close the torrent
# system.method.set = group.seeding.ratio.command, d.close=
# Move files to ./unsorted when download completes
system.method.set_key = event.download.finished,move_complete,"execute=mv,-n,$d.get_base_path=,~/torrents/complete/;d.set_directory=~/torrents/complete"
# Port range to use for listening.
port_range = 33101-33199
# Start opening ports at a random position within the port range.
port_random = yes
# Encryption options, set to none (default) or any combination of the following:
# allow_incoming, try_outgoing, require, require_RC4, enable_retry, prefer_plaintext
# The example value allows incoming encrypted connections, starts unencrypted
# outgoing connections but retries with encryption if they fail, preferring
# plaintext to RC4 encryption after the encrypted handshake
encryption = allow_incoming,try_outgoing,enable_retry,prefer_plaintext
# Sort the main view by ratio
view.sort_current = main,greater=d.get_ratio=
view.sort_new = main,less=d.get_ratio=
view.sort = main
# Sort the seeding view by the upload rate and only show torrents with peers
view.sort_current = seeding,greater=d.get_up_rate=
view.filter = seeding,"and=d.get_complete=,d.get_peers_connected="
view.sort_new = seeding,less=d.get_up_rate=
view.sort = seeding
# Sort the leeching view by name
view.sort_current = leeching,greater=d.get_name=
view.sort_new = leeching,greater=d.get_name=
view.sort = leeching
# Filter the active view by connected peers
view.sort_current = active,less=d.get_name=
view.sort_new = leeching,less=d.get_name=
view.filter = active,d.get_peers_connected=
view.sort = active
schedule = sort_main,11,5,view.sort=main
schedule = sort_seeding,12,5,view.sort=seeding
schedule = sort_leeching,13,5,view.sort=leeching
schedule = sort_active,14,5,view.sort=active
# Enable DHT support for trackerless torrents or when all trackers are down.
# May be set to "disable" (completely disable DHT), "off" (do not start DHT),
# "auto" (start and stop DHT as needed), or "on" (start DHT immediately).
# The default is "off". For DHT to work, a session directory must be defined.
dht = auto
# UDP port to use for DHT.
dht_port = 6881
# Enable peer exchange (for torrents not marked private)
peer_exchange = yes
# webui
scgi_port = 127.0.0.1:5000
create this service file at /etc/systemd/user/rt.service
sudo nano /etc/systemd/system/rt.service
[Unit]
Description=rTorrent
After=network.target
[Service]
Type=forking
KillMode=none
ExecStart=/usr/bin/screen -d -m -fa -S rtorrent /usr/bin/rtorrent
ExecStop=/usr/bin/killall -w -s 2 /usr/bin/rtorrent
WorkingDirectory=%h
[Install]
WantedBy=multi-user.target
then its time to fire up rtorrent
systemctl enable rt
systemctl start rt
now for the more advance parts for the webui
(coming soon gonna use nodejs)
Works on RPI 1 & 2, Vero
