That was my first thought but i used a copy & paste of the password in FSTAB to login to my Freebox, unless i need to reboot it for my Vero 4K.
Try that as maybe the automount process cached the password
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Aug 16 13:40:04 2017 from 192.168.0.31
osmc@osmc:~$ ls -lah /mnt/FREEBOX_Films
ls: cannot open directory /mnt/FREEBOX_Films: No such device
osmc@osmc:~$ ls -lah /mnt/FREEBOX_Series
ls: cannot open directory /mnt/FREEBOX_Series: No such device
osmc@osmc:~$ ls -lah /mnt/FREEBOX_Musique
ls: cannot open directory /mnt/FREEBOX_Musique: No such device
osmc@osmc:~$ ls -lah /mnt/FREEBOX_Media
ls: cannot access /mnt/FREEBOX_Media: No such file or directory
osmc@osmc:~$ grab-logs -A
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/xemeqivemi
osmc@osmc:~$
Nope, of course i can try another password but …
So now suddenly none of them is working?
Edit : i see this in the log :
Pi config error
advancedsettings.xml error /i deleted it earlier
"Interesting"point, maybe just for me, i found a FSTAB file in .kodi/userdata with my old password
With the lack of understanding I have of the subject i see the following options :
What do you think ? Thanks !
Just delete it, should not be there anyhow
It’s not working.
I found, in .kodi/userdata/, a file named password.xml, with one the 3 shares and my previous password. Changing it did no help.
If you’re mounting the shares via /etc/fstab, then you are
not using the sources in Kodi XML, so the password doesn’t
need to be updated there.
Does cat /etc/fstab show your fstab is up to date with the new password?
What does the output of sudo mount -a show?
Ok
#/dev/vero-nand/root / ext4 defaults,noatime 0 0
//192.168.0.254/Films /mnt/FREEBOX_Films cifs x-systemd.automount,noauto,iocharset=utf8,user,username=danielbachelay,password=,uid=osmc,gid=osmc,iocharset=utf8,file_mode=0770,dir_mode=0770,vers=1.0 0 0
//192.168.0.254/Series /mnt/FREEBOX_Series cifs x-systemd.automount,noauto,iocharset=utf8,user,username=danielbachelay,password=,uid=osmc,gid=osmc,iocharset=utf8,file_mode=0770,dir_mode=0770,vers=1.0 0 0
//192.168.0.254/Musique /mnt/FREEBOX_Musique cifs x-systemd.automount,noauto,iocharset=utf8,user,username=danielbachelay,password=,uid=osmc,gid=osmc,iocharset=utf8,file_mode=0770,dir_mode=0770,vers=1.0 0 0
Nothing
Sorry, should be sudo mount -av (for verbose)
No problem
osmc@osmc:~$ sudo mount -av
/mnt/FREEBOX_Films : ignored
/mnt/FREEBOX_Series : ignored
/mnt/FREEBOX_Musique : ignored
osmc@osmc:~$
Any idea ? I bought the Vero 4K as a present, don’t know what to says. Thanks
It shouldn’t be this complicated to mount a CIFS share.
Are you sure the password is correct?
fstab itself looks OK, so reboot and checking /proc/mounts (cat /proc/mounts) will show a list of mounted filesystems.
Password problems are frequent but i copied the password from FSTAB to paste it @192.168.0.254, it works.
What is the exact command line please ? Thanks
Hi there. Could you answer each numbered question for us.
1 What is the output from running ls -la /mnt
2 You say you changed your password “for securiy reasons”. For now, please change it to ABCD1234 and then reboot your FREEBOX server. Please confirm that you have changed the password.
3 Include this new password in your /etc/fstab file. Then show us the output from cat /etc/fstab.
4 Then show the output from running sudo mount -av
Before your post, i changed back the share password and FSTAB, it seems ok. I’m scrapping Freebox_serie right know
I’m gonna post the result of this command line asap
So:
Point 1:
osmc@osmc:~$ ls -la /mnt
total 16
drwxr-xr-x 7 root root 4096 Jan 1 2015 .
drwxr-xr-x 23 root root 4096 Aug 14 21:13 …
drwxrwxrwx 1 osmc osmc 0 Aug 12 11:18 FREEBOX_Films
drwxrwxrwx 1 osmc osmc 0 Aug 1 22:47 FREEBOX_Musique
drwxrwxrwx 1 osmc osmc 0 Aug 7 21:14 FREEBOX_Series
dr-xr-xr-x 2 root root 4096 Jan 1 2015 FREEBOX_media
drwxr-xr-x 2 root root 4096 Aug 15 15:33 test
Point 2:
As i wrote i came back to the previous password. I can make a test with this third password tomorrow but it’s not my Vero 4K, i needed to make it work tonight.
Point 3:
osmc@osmc:~$
Anything else ?
So are all three mounts are working now?
If not than post grab-logs -A
They’re working with the old password, but i can’t change it, and i have playback problems. Thanks.
