UPDATE:
This is related to the samba update on Arch Linux from 2016-09-11. As a solution, ~/.smb/smb.conf on the RP has got to edited like in post #14.
Thanks for the hint…changed it in the config files - but no change. When using the GUI to add a source, after entering path and credentials and clicking ok, the dialog just stays there…
Log file looks the same, just with the IP adress instead of the server name.
Just wanted to let you know that i have the exact same problem. Smbclient is working fine! Tried installing a fresh OSMC but to no avail. All other systems (OSX, Windows 10, Arch linux and one openelec) is able to access the files.
UPDATE
Just noticed that i can add my NAS (Qnap 412) samba shares without problems. The server i’m having trouble with is running Arch Linux with the latest Samba install.
Hm, I’m running Arch Linux on the server, so samba is the latest version and got updated 2 weeks ago. Config files haven’t changed - maybe there is some incompability with the latest samba version?
Like I said, all other machines work and I can also browse the server from the command line on the RP.
Not tried, not possible in my case anyways. Many kodi installations running with a SQL database. And why would one get better performance from mounting via fstab?
Because Kodi’s built in smbclient has never performed as well as kernel based. Have you tried rebooting the server or the router or any switches in between?
Thank you - this will also be the solution for any media centers/servers/nas/file-servers upgrading to the upcoming Debian Stretch (or similar) which will bring in Samba v4.5+
