Standby meaning technically full shutdown? (red LED)
Is there a way to map IR remote to turn on the Vero? That would be amazing.
I have remote from S905 box too, btw. But doesnt seem to work with vero.
It sadly doesnât work with all remotes from S905 box. And yes: Standby means red LED.
Why not use a staples power strip with master control . I have used this one for years and it works very good You set the TV as Master and DVD-player, amplifier, Vero /raspberry, etc as slaves. Then you adjust the switching treshold to fit when shutting down all of your equipment and then you can use your Tv remote control to shut down or turn on all of your equipment.
This is a good workaround, but requires additional money to be spentâŠ
If its possible to shutdown and wakeup vero in future with remote, i will be patiently waiting.
Well, my choise was to buy a programable remote control to be able to turn on and off my LG TV,Rotel amp. , LG DVD, Denon tuner. A Master slave solution is much cheaper, 139 Skr or ÂŁ13
Iâm very very pleased too with the Vero-4K which is a very well designed and evolutive product. But here is my request concerning Power management:
I do use a âstaples power strip with master controlâ that allows me to power off the TV and its surrounding equipments before going to bed. But before pushing the remote button that will cut the electric power source, I have to switch off the Vero 4K (to be sure is it not being working at that moment).
Currently I have to go the main menu, then go down to Power menu and choose the âPower offâ command (or something like that because my UI is in french). I know that itâs not a real Power-Off, but it is quite a Stand-By state allowing to cut the power (and to unplug the USB external disk) safely.
Therefore I would just need to be able to call this âPower offâ command from the Vero 4K standard remote. Could you please sum-up briefly how to do this ? For instance by assigning the âHomeâ long press to this ? Any suggestion ?
Thanks in advance for your kind support.
Best Regards,
Eric
In /home/osmc/.kodi/userdata/keymaps/ make sure there is a file called remote.xml
If not, you have to copy it first from /usr/share/kodi/system/keymaps
After that, you need to open /home/osmc/.kodi/userdata/keymaps/remote.xml with the nano command. When in that folder typ ânano remote.xmlâ.
You need to decide how you want it to work. Like, the Home button should do one thing when in videos, but when your at home menu, THEN it should power down.
In that file itâs kind of logical how it works. Find out what the name of the button is, and what the correct command to Power off isâŠ
I hope this helpsâŠ
/Söder
If youâd like to do this with a GUI, Iâd recommend this addon: https://kodi.wiki/view/Add-on:Keymap_Editor
Itâs even more straightforward and self-explanatoryâŠ
Indeed that was easy thanks to this addon. Thank you very much for this piece of advice that helps a lot.
@soder : Thank you too for taking the time to explain the manual way step by step !
I just noticed that after doing âPower offâ (red led), the power supply plug of the Vero 4K is making some noise (but not when it is on). Thatâs not a problem because I switch off the main power plug just after that.
Eric
hi all
currently thinking about getting Vero 4K but before hitting the buy button I need to know if I can properly integrate it with my Home AutomationâŠ
I already bought a 4k capable box once only to resell it once I realized I couldnât turn it on with my devices over WOL or a controlled outlet.
so:
When I cut power to the Vero 4K and re-establish power will it automatically boot up?
As I understood WOL is not supported?
Thanks!
If you mean physical power, yes
No WOL at this time.
Perhaps if you can clarify things in more detail we can advise further
Guys, I also really like the Vero4k so far. But the power off and on thing is really an issue for me.
The box gets quite warm so leaving it 24/7 on is not a real option.
What about a standard behaviour like if you press the home button for 5 secons you trigger the power off from the menu.
Currently I can turn it on toggling my power strip. That would be a good behaviour as long as the USB power on off feature is not there yet.
Jay
The Vero 4k is designed to run 24/7, so it wonât be any problem if it warms up a bit. If you donât place it on or close to a heater or a very hot AVR it should be absolutely fine. ![]()
There wonât be a USB on/off feature with the Vero 4k as stated above in this thread - any form of wakeup from anything else than the suspend mode - which is already available - isnât possible (not via USB, WOL or anything else).
You can very well configure your remote to your liking by mapping the shutdown command to a key manually. AFAIK, long-press commands are not yet supported by the OSMC remote.
If you need any advice as to how this is done, just give us a ping or have a look at this very useful Kodi addon: https://kodi.wiki/view/Add-on:Keymap_Editor
The suspend mode should do the trick
I use Harmony (+SmartThings) to control all my HiFi components so I decided to add my Vero4k. I know it doesnât use much power but I decided to add it anyway (and I donât like the bright blue light that much). A smartplug turns on a several devices including the 4k when my HTPC activity starts. On shutdown, Harmony sends a command to put the 4k into standby (remapped similar to above) and the smartplug switches off after a 1 min delay. It works well but it was more complicated to setup than I expected.
I hope you mean to shutdown not standby
Yes, correction, shutdown (red light)
And what about Veroâs operating system? It will somehow harm it, if I will power it off by pulling out power cable? As we all know, this is not a safe way to turn off devices with running OS. It need to be shut down properly. I dont wanna risk that one day it wont boot up, because of corrupted filesystem or OS.
I noticed, that in february update, it was added:
âAdded standby / suspend support for Vero 4Kâ
âŠdoes anyone knows, how it works? It will somehow put Vero to sleep, like a PC does? Or there is standby mode as we know it from other electronics, and I can turn on Vero by remote?
