====================== APT sources.list =================== ZZz2wrJ1
deb http://ftp.debian.org/debian buster main contrib non-free
deb http://ftp.debian.org/debian/ buster-updates main contrib non-free
deb http://security.debian.org/ buster/updates main contrib non-free
deb http://apt.osmc.tv buster main
deb http://apt.osmc.tv videoimprovevero main
---------------------- APT sources.list END --------------- ZZz2wrJ1
Your missing a 49 in your source list. Check the first post in this thread as it has been updated. Once you fix this file you can run apt-get update && apt-get dist-upgrade
Yep - that was my thread and Sam confirmed the issue would be resolved in the next kernel update. The new update says “Add support for Docker” but unless I’m missing something the fix hasn’t been added? I doubt myself because I’m not a programmer but cannot find any way of getting Docker working now.
I currently have my vero running through an oppo 203 to take advantage of the tone mapping as my projector needs the hdr to sdr conversion. Is it automatic on the vero or there are settings to play with?
Ok thanks. I’ll do a quick comparison to see the difference. My projector accepts an 18gps signal but I need to change the color space manually to bt.2020.
Yes it does. It’s a JVC RS500. The built in HDR settings render a picture that is too dark. The HDR to SDR conversion provides a much better and brighter option.
Yeah. I could never get comfortable with having to hook my laptop up to the projector and mess around with it that way. I guess I need a little more courage lol.
running latest test version, noticing some sad-face events on chapter skips, just done a bit of mkv testing from 4K rips. Not sure if this gives anything useful.
EDIT: wonder if this is because I happened to be playing with sending hi-res audio to the AVR via PCM, I’ve seen that crash playback before, passthrough may be good.
