Will this probably work for longer or is a slight change in encrypting e.g. by Netflix enough to break the support?
Hmm, nobody knows! On the other hand tv is stuttering much more than before, but you canāt have everything by now!
Yep, I know⦠But it would be great, if Netflix and Amazon would tolerate all this. Itās not breaking encryption and gives them more customers probably.
Exactly, in my opinion thereās nothing illegal, we pay for it and itās no hacking! I donāt think they will.
cu
Ofcause⦠it have nothing to do with hacking! - I am still waiting for the automatic stretch upgrade before i will upgrade kodi to 18, so i can watch netflix directly.
I wish the same was possible with HBO Nordic⦠but who knows in time ?
Rgds; Jesper.
But u have to be clear that in kodi 18 only one skin is available and u definitely recognize the alpha-state, so somehow a step back, but for me itās worth it!
cu
You can hack OSMC skin to āworkā with v.18, some grapics/text missing. But usable, had some stabillity issues, but i dont know if thatās skin related.
Where there is missing graphics/text you can often click there to get function anyway.
Ah, ok, good to hear!
Would u tell me how? We have to live with the issues for now, thatās the same here!
cu
nano /usr/share/kodi/addons/skin.osmc/addon.xml
Change ā5.12.0ā to ā5.13.0ā and save.
THIS IS A HACK, more work is needed to get the thing working as it should, but iām not fluent enough in skinning to work it out yet.
Cool, thx!
Hello fellow osmcās here
ā¦
-First off i am pleased that this forum is so nice, and people here also.
My update to stretch went well without any problems during install (watched it on big screen from couch with coffee).
So next step is to install kodi 18
Any best way to do this ?
Thanks very much all.
osmc@osmc:~$ cat /etc/apt/sources.list
deb Index of /debian stretch main contrib non-freedeb Index of /debian stretch-updates main contrib non-free
deb http://security.debian.org/ stretch/updates main contrib non-free
deb http://apt.osmc.tv stretch main
#deb Index of /debian sid main
osmc@osmc:~$ kodi --version
17.6 Media Center Kodi
Copyright (C) 2005-2013 Team Kodi - http://kodi.tv
osmc@osmc:~$ uname -a
Linux osmc 3.14.29-51-osmc #1 SMP Tue Jan 2 09:35:33 UTC 2018 aarch64 GNU/Linux
osmc@osmc:~$ df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 785M 0 785M 0% /dev
tmpfs 895M 8.5M 887M 1% /run
/dev/vero-nand/root 14G 1.8G 12G 14% /
tmpfs 895M 0 895M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 895M 0 895M 0% /sys/fs/cgroup
tmpfs 179M 0 179M 0% /run/user/1000
The instructions are very clear here.
Thanks⦠went fineā¦
I searched but did not get clear howto install netflix now ?
18.0-ALPHA1 Media Center Kodi
Exactly synchronous!!!
You have already asked, and got exactly the same answer. NETFLIX wannabee ! - I would like some guides
Yes⦠i see; got confusedā¦
Anyway itās working perfectlyā¦
Rgds; Jesper.
Heyā¦
osmc@osmc:~/.kodi/temp$ cat /etc/debian_version
9.3
The other day netflix suddently stopped working. I did not do much fault clearance yet, but would like to know if others experience the same issue ?
I will ofcause paste logs etc⦠if anyone here sayās so! - But for a start just hear if itās just me having this issue ?
Good evening and rgds; Jesper.
Hi @lykkedk,
only had an issue with amazon, which was related to an old libwidewine, in this case search for an error in ur kodi.log that looks like this:
11:14:25.802 T:3461006224 NOTICE: Creating InputStream
11:14:25.929 T:3461006224 ERROR: GetDirectory - Error getting /usr/lib/kodi/addons/inputstream.adaptive/
11:14:26.369 T:3461006224 ERROR: Interface_Filesystem::get_property_values - invalid data (addon='0xd15a16a0', file='0xd157d990')
11:14:27.157 T:3461006224 ERROR: AddOnLog: InputStream Adaptive: Unable to find license;hdcpEnforcementResolutionPixels in JSON string
11:14:27.157 T:3461006224 ERROR: AddOnLog: InputStream Adaptive: License update not successful (no keys)
11:14:27.158 T:3461006224 ERROR: AddOnLog: InputStream Adaptive: Initialize failed (SingleSampleDecrypter)
