Hi, I know this question is asked many times before and I think I read all the replys but I still have the same problem. I can’t get any sound from my Atmos enabled speakers. I am using vero 4k plus with my Sony dn 1080. I am using the passthrough option enabled, Sync Playback off, Adjust Refresh Rate enabled. I see True HD on on my AVR screen but not Atmos. As I know Atmos is part of True HD but the thing is I get no sound from the Atmos enabled ones. I use 5.1.2 setup. Other things are all good. I get sound from every speaker except that two.
Is there anyway to change the subtitle font to calibre and is it possible to use the remote with Samsung tv ( the CEC thing) Thanks in advance.
Note: All the movies I tried has Atmos and also tried a file called something with helicopters Atmos demo.
Thanks for the quick reply. As I mentioned I tried them and I can see True HD on my AVR screen but the thing is no sound on the 2 Atmos enabled ones. When I try a sound test on my Sony dn1080 AVR I can hear them working fine. So I think this is something to the with the settings of my Vero 4k plus. Thanks again.
I solved the Atmos issue from my AVR, Disable the DTS X and enabled it again. Now I see Atmos on my AVR screen. I hope it won’t broke again because it doesn’t look like a proper fix to me, so fingers crossed. Now can you help me with the other part.
I also can’t open Vero from the remote, every time I take the power cable off and put it back.
Thanks for all the replies. I am getting server response 553 cannot create folder error while trying to ftp the font. For now that’s the only problem I have. Things are getting better thanks to you guys.
Tried this but couldn’t find /home/osmc/.kodi/media/Fonts/
So tried this but couldnt upload /usr/share/kodi/media/Fonts/
