Kodi never reads aud_cap. If you have a look in .kodi/temp/kodi.log you should see this, even if your hdmi cable is unplugged:
17:26:58.521 T:4080894544 NOTICE: Enumerated ALSA devices:
17:26:58.521 T:4080894544 NOTICE: Device 1
17:26:58.521 T:4080894544 NOTICE: m_deviceName : default
17:26:58.521 T:4080894544 NOTICE: m_displayName : Default (AML-M8AUDIO Analog)
17:26:58.521 T:4080894544 NOTICE: m_displayNameExtra: PCM
17:26:58.521 T:4080894544 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:26:58.521 T:4080894544 NOTICE: m_channels : FL,FR,UNKNOWN1,LFE,FC,BC,BL,BR,BLOC,BROC
17:26:58.521 T:4080894544 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
17:26:58.521 T:4080894544 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
17:26:58.521 T:4080894544 NOTICE: m_streamTypes : No passthrough capabilities
17:26:58.521 T:4080894544 NOTICE: Device 2
17:26:58.521 T:4080894544 NOTICE: m_deviceName : hdmi:CARD=AMLM8AUDIO,DEV=0
17:26:58.521 T:4080894544 NOTICE: m_displayName : AML-M8AUDIO
17:26:58.521 T:4080894544 NOTICE: m_displayNameExtra: HDMI
17:26:58.521 T:4080894544 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
17:26:58.521 T:4080894544 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
17:26:58.521 T:4080894544 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
17:26:58.521 T:4080894544 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
So, in summary:
- activate the logging
- reboot the OSMC device
- reproduce the issue
- upload the log set either using the
Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
- publish the provided URL from the log set upload, here
For your case, please re-boot with your AVR off then turn on AVR and display then immediately try playing a track/video which you know doesnât produce sound. Upload logs.
Can you also confirm âno soundâ applies to GUI sound as well, or just passthrough formats?
