Indeed.
Unless you have a specific need to use dist-upgrade (you’re at work for example), I’d recommend you upgrade via the TV
Indeed.
Ok,
Something else. I feel a slight slowdown (fps slow) in menus home or playlists, I come back during playback
Is it because of the version 15.1?
Please create a NEW THREAD in the appropriate Help and Support category for technical/support issues! The release announcement thread is not intended for this.
Great thanks!! Updating again solved the problem with hifiberry! Works like a charm!
I upgraded via GUI. Since that I did a command line upgrade too. I’ve restarted several times.
Here you can see the logs:
http://paste.osmc.io/ecodumosoc.vhdl
http://paste.osmc.io/pahavumucu.vhdl
http://paste.osmc.io/qirosuqofe.coffee
If I turn off and on the monitor it works. But it’s very annoying.
Just a quick data point on a Raspberry Pi 2.
I had changed my config.txt to add “dtoverlay=sdhost”.
After a reboot, dmesg shows:
mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
I have been running fine for the past 24 hours, 2 updates and adding the Plex Media Server package.
All seems well at this point.
is it possible to turn off adaptive seeking?
Hi Sam,
I’m having problems in the database update (from version 90 to 93). I get a Segmentation fault, and an empty (93) database. Further attempts to load kodi show the sad face (becase there are no tables in the current database).
Thinking it could be a memory issue, I enabled temporariliy 512Mb of swap, but the result is the same.
Rasperry Pi 1, model B (512Mb).
Can I force the database update manually? How should I proceed? Is there any way to revert to kodi14 (or any other previous version) for the sake of exporting the database and importing it on a new database?
Thanks,
Julian.
I believe you can change the skip steps in Settings.
Unfortunately in our testing we also saw the sad face too with the initial boot when the database is upgrading.
I would suggest dropping the empty schema and, if you have one, using a client with more resources such a s a desktop to perform the database upgrade.
Hope this helps
Thanks for your reply. I noticed it happened too with the windows version just downloaded from their site
What I did to get it working again (I used the windows builds for speed):
i can’t understand… how i can know if i use mySQL database ?
Do you know you use MySQL?
No?
Then you don’t use MySQL.
See: http://kodi.wiki/view/Skip_steps
“With no more than a single negative or positive step configured,
together with Skip Delay set to none, then Kodi will instantly skip
without a delay.”
Since the last update on my Raspberry pi 2, i can’t play anymore many movies and i feel a big slowdown on the most of the others.
After some research, i understood that the default player become mmal (dvdplayer) and not omxplayer like before.
After setting back omxplayer as default player and unselect new dts-hd decoder (because omxplayer doesn’t seem to be compliant). All works fine now !!! Children are happy !!!
Is this version using Kodi 15.1 RC? It seems my system is running osmc from Kodi 15.1RC (updated via command line)
Thank you, but the Kodi iPhone app says it is the 15.1RC. Am i missing something?
