Composite output in Raspberry Pi fix!
HowTo Raspberry Pi Help and Support
I’ve just discovered how to solve the very annoying issue regarding the black screen after the boot splash screen!
I spent 3 days trying to solve this, trying almost every single suggestion in the OSMC and LibreELEC forums and that’s how I was able to do it:
  1. Download the 2023.08-1 release of OSMC on your PC
You only need to do this step if you only have a composite TV to work with. If you have an HDMI-capable screen, you can temporarily connect your Raspberry Pi to it for now! This is only so that you can see when the loading ends and avoid corruption if you remove the SD card before it finishes
  1. Flash it on an SD card and edit the following files:
  • config.txt
    Add the following lines:
display_auto_detect=1
dtoverlay=vc4-kms-v3d,cma-384,composite=1
  • cmdline.txt
    Add a space and add this line right after the code that’s already in there (DO NOT ADD AN ADDITIONAL LINE WITH ENTER! When I did this, it stopped working for me):
For NTSC
video=Composite-1:720x480@60ie
For PAL
video=Composite-1:720x576@50ie
  1. After that’s all done, insert the SD card into your Raspberry Pi and you’ll see the OSMC loading screen. Wait until it’s all done!
  1. Now that the loading is complete the Raspberry Pi will reboot and you’ll get a black screen right after the splash screen, but don’t worry! We’ll fix it now.
  1. Remove the SD card from the Raspberry Pi and insert it into your PC
  1. You’ll again have to change some files:
  • config.txt
    Add a # right before the first line of the [all] section on the code. It’ll look just like this:
[all]
#dtoverlay=vc4-kms-v3d,cma-512
dtoverlay=
disable_overscan=1
disable_fw_kms_setup=1
disable_overscan=1
start_x=1
disable_splash=1
hdmi_ignore_cec_init=1
include config-user.txt
  • config-user.txt
dtoverlay=audio=on
dtparam=audio=on
  • cmdline.txt
    The exact same changes as before! Add a space and add this line right after the code that’s already in there (DO NOT ADD AN ADDITIONAL LINE WITH ENTER! When I did this, it stopped working for me):
For NTSC
For PAL
  1. Insert the SD card back into the Raspberry Pi and presto! You should be getting a composite output!
Here are the links that helped me get this result:
I hope I was able to help :bowing_woman: English is not my first language so please correct me if I said something wrong here
If you’d like and change the title of the post we could move this over to the howto section.
You might consider adding an alternative option where one just uses ssh and nano instead of swapping the SD back and forth. Also have you checked to see if this options work in config-user.txt instead of config.txt. Although not all options work in the includes file this is the prefered location as updates might overwrite config.txt at some point but config-user.txt will not be touched by updates. Nice work on the guide. :+1:
This might be a dumb question, but is there a way to set it up so this issue is circumvented, but you still have the option to use HDMI to a higher quality display? As it stands I get the black screen after booting up except it’s on the HD tv, while composite works fine.
Thanks!
If anyone is wondering the same thing I currently work around this adding two lines in config.txt
I comment out the composite line if I’m using HDMI, and vice versa for Composite on CRT. I also comment out the added line in cmdline.txt for HDMI.
I added all the lines that go in config-user.txt into config.txt. I know this is not recommended to do but for some reason my config-user.txt kept getting wiped and stopped working with my CRT, and I’d have to redo the whole process. I also found extreme lag if I forgot to add the dtparam=audio=on line when going into settings.
